Results 1 to 10 of 17
Thread: Facet fuel pump - help please
    Sir Royston Guest
    Would be glad of some help please:
    Just fitted a Facet 40105 to my AT (1998 /14000 miles). There was nothing wrong with the original, but I'm off to Timbuktu in January and having read on this forum that the OE Honda pump can and does fail without warning, I thought I'd fit the Facet as a precaution. I bought the pump from the shop on this site, and it went on OK, the bike starts OK, but petrol is dripping from the carb overflow tubes, which didn't happen before the conversion. Had the needle valves out again and there's no problem with them, so don't know what to do about this problem.
    Would be very grateful if someone can offer advice or solution
    Thanks in anticipation
    GSPD750's Avatar
    GSPD750 is online now Senior Member
    Calgary, Alberta Canada
    Re: Facet fuel pump - help please
    It's as if your fuel pressure is on the high side. Check that you recieved the correct pump. Should read 40105 on the mounting lugs you cut off.
    The orientation of the pump or position should not make a difference.
    Someone else here mentioned they had the same problem you are experiencing so you are not the first. I know alot of members here are using the same pump with no problems...so the only logical explantion are your carbs. What it is in the carbs...I don't know. Have you ran it hard and fast? Still leaking? See if you can isolate to which carb by using an independent drain line to each and bagging it.
    matt Guest
    I put a small car fuel filter in line, replacing the OEM one, when I replaced my welded together OEM pump. This might have an effect on the fuel flow rate, but not the pressure.
    A small bit of grit is all it takes to stop a seal working.
    Also consider leak from elsewhere tricking you, like a split pipe.
    Sir Royston Guest
    To the two chaps/esses who have responded already, thanks very much. I'll have a look again at this at the weekend - I'm hoping that a good thrashing will make it behave properly, it usually does....
    Thanks again
    Steve C's Avatar
    England - landed in Yorkshire
    Quote Originally Posted by Sir Royston View Post
    Don't fret Sir Roy
    I had same experience; it took a few days to gradually slow to nothing more than a smell and then stop altogether - 5 or 600 miles, about a week or so in my case. Hang in there
    !Boris!
    !Boris!!Boris!
    Sir Royston Guest
    Thanks Steve,
    I'm hoping this works for me, it being an option with minimum hassle/aggro, which is good at this time of the year, also me wanting the bike fully sorted fairly soon for the Timbuktu jaunt. Cheers
    Sir Royston of Feckem Hall
    Steve C's Avatar
    Thanks Steve,
    and you offically have my envy too!
    !Boris!
    !Boris!!Boris!
    Chad's Avatar
    Chad is online now whys the rum always gone?
    wickford,essex
    i never had any problems with the facet on my RD07have the pumps changed at all ...you know how manufacturers love to feck about with something that works balls it up and call it an upgrade
    guess i'll find out soon as i'll put one on the RD04
    Steve C's Avatar
    Quote Originally Posted by Chad View Post
    Well, this is guesswork of a confessed nutter, but I've assumed that the new pump does give higher pressure than a worn OEM pump and it just takes a little while for the needles and floats to bed in again. The OEM has some kind of bleed on the carb side that isn't there on the Facet - to release pressure after the bike's switched off?
    As I said, nutter's ramblings...
    I know, I'll tell you all about the effect absent fathers have on their adult children instead
    !Boris!
    !Boris!!Boris!
    Chad's Avatar
    wickford,essex
    Quote Originally Posted by Steve C View Post
    no it makes sence mate as for the last bit you dont need to tell me ...i bought a pink twin FFS
  1. Facet fuel pump
    Last Post: 06-06-07, 10:29 PM
  2. Facet Fuel Pump
    By loftyjohn in forum Africa Twin
    Last Post: 18-04-07, 04:30 PM
  3. Facet Fuel Pump, Clicky?
    By mgillespie in forum Africa Twin
    Last Post: 13-11-06, 09:35 PM
  4. Facet Fuel Pump
    By DaveS in forum Mechanical Advice
    Last Post: 19-02-06, 12:55 AM
  5. Facet Fuel Pump
    By DaveS in forum Africa Twin
    Last Post: 01-01-70, 08:27 AM
