Re: Push or Pull throttle cable????
Originally Posted by
Gromit3528
I have often wondered if you had your "pull" cable fail in the middle of nowhere could you adapt the push cable to operate in pull mode.
Has anyone tried this?
Yes...sort of.
Pull cable on my FJ1200 snapped. Went to swap over the cables so the push became pull, but could only get to one end, the crappy Yamaha screwdriver supplied wasn't up to undoing the crosshead screws at the handlebar end.
Result was a throttle that worked perfectly normally.......but you twisted it forward to accelerate and backwards to slow down.
20 years of riding every day meant that I kept revving the b*llocks off it when I should have been closing the throttle. I made it the 50 miles home, a bit sweaty, but in one piece. The motorway was fine, it was the roundabouts that were a bit hairy.
