A complete make over by removing existing original Speedometer/tripmeter. Replaced by a Trail tech "Vapour" AKA "Tripmeter/Speedometer"
An analog Speedometer from Honda NSR125..with easy modification on connection cable..
RAM mount(Locked knob) with Garmin 60 CSx.
12V cigarette socket (With cover-waterproof) just below the GPS left side..too dark to be seen... with switch on/off. Master switch is powered on by relay activated Ignition on signal.
Voltage meter but only activated with no lights on--(Tapped from 1 of the live wire from trip meter cable)..
Countless of DIY hours on it.... but its worth it.![]()
