Annette
Some food for thought on your problems.
Battery
Did you leave your curlers plugged into the bike? Just kidding!!!
- no curlers must have been the hair straighteners!!
Funny things happen to perfectly good bikes as the the cold weather arrives, especially if they live outside.
As you try to start it, do the headlights dim? Does the solenoid or starter motor just click? These are a sure sign it IS the battery, however if the headlights remain bright, and it doesn't have the gut to turn over, you're looking at the started circuit, and particularly the thick cables that run from the battery, to the frame, and to the solenoid and onto the starter motor. Give them a clean, tighten, and a quick spray of WD40.
From what you've said here it's definitely the battery. I've changed it today (4 x Duracelll D batteries are OK aren't they). Kidding, only took half an hour to change it...and without any male supervision what so ever and it starts fine.
Speedo
This could be the bike complaining that you are a laydeee rider and it has not been treated to a blast over 30mph yet!! Kidding again!!!
Does it go as slow as 30?
Could be three things. The actual speedo = unlikely, the cable = maybe, the speedo drive = possibly.
Put the bike on the centrestand if you have one, and disconnect the speedo cable from the drive unit.
I've no centre stand yet but I can put it on a paddock stand (muscles are already flexing in anticipation
) Tilt the bike back so the front wheel is airborn and turn the front wheel. Can you see the little slot inside the drive (where the cable would mesh to) turning? If yes, suspect the cable. If NO, the drive can be replaced (expensive) or rebuilt
Transalp Speedo Drive Repair
When my speedo drive packed up, it also fouled up inside, making a horrible noise and making the front wheel hard to turn, and the bike to push. Could this be confused with your neutral fault??
I'll take a look at this at the weekend. There is a bit of a funny vibrating noise but it's fairly quiet so it could be the speedo drive so therefore it could be causing the neutral fault.
Sidestand Switch
Again, the bike is complaining that it is being ridden by a female and spends too much time being admired and not thrashed! Last one, I promise!!
Admired - it could be complaining it's not cleaned enough and looking very grubby beside Stormforce8's gleaming, sexy machine.
This could be your most simple one. It may be just dirty or gummed up, so keep squirting WD40 into it whilst working the switch in and out. If it don't work, you aint gonna make things any worse! Hopefully this will sort it out.
Again I'll give this a go at the weekend.
The worse one
I think to be fair the bike has just had enough of you, and is digging it's heel in refusing to move. Try whispering into one of the mirrors that you WILL promise NOT to take it shopping any more, and will go for a nice long blast as soon as it's better !! I couldn't resist it!!
The only shopping it gets is to Infinity for bike bits...Even a bike couldn't complain at that. Could just be fed up of going to work and needs a holiday
OK, you've check the oil grade, level, clutch adjustment etc.
What springs to my mind are the following...
Chain. Is it lubed, and
adjusted OH SO
slackly sir?
Belive it or not, a badly adjusted chain will also affect your gearchanges AND finding neutral.
Chain is perfect. I thought it was a bit slack compared to my F650GS, but I'm told it's just right and I have a scottoiler which is working perfectly. So I think I can discount this. Both chain and sprockets and in extremely good condition.
Rear wheel bearings. Get the rear wheel airborn, try turning it in neutral, with the clutch in, and preferably after you've slipped the chain off the sprocket as well.
Again I'll try this again at the weekend. Didn't even think of that one.
Rear Brake. Is it binding on the rear disc and making pushing hard?
Not as far as I can see but I'll check it out.
Pray it is nothing inside the gearbox department, which I'd be surprised if it was. It may ne worth checking the output shaft and the shaft bearing, but I'd do that last, and after taking a few valium.
OK, there's a few pointers then, which I hope are of some use.
Good Luck
