Results 1 to 4 of 4
Thread: Rear Brake Disk Cleaning
    vrooom_uk's Avatar
    vrooom_uk is offline Daddys Got Two Wotobikes
    North Yorkshire
    Talking Rear Brake Disk Cleaning
    Hello Bikey Peeps.
    Just looking at my rear brake disk , looks like a lot of surface cack, light rust dust, and also snags just a little.
    Does anyone have any suggestions for cleaning materials for the disk and the brake calipers/ pads.
    TA
    Lumiya's Avatar
    Ziost
    Re: Rear Brake Disk Cleaning
    Quote Originally Posted by vrooom_uk View Post
    Hello Bikey Peeps.
    TA
    YEP, Brake cleaner as sold in a spray tin by all bike shops.
    Petrol (just don;t use diesel as it leave an oily residue behind) is just as good though brake cleaner being a spray helps you get in all the nooks and crannies. Just be warned that whatever you clean it with if you clean the pins on which the calliper moves on then you will need to regrease them (preferably with a High Melting Point grease.
    Kymmy
    Lord Stig's Avatar
    May 2004
    West Lothian
    For the surface rust I just use an abbrasive pad - the kind you would use for the dishes (Scotchbright or whatever it's called). The snagging might be the caliper binding though - I thought that was nice and clean....indeed, I cleaned it myself, though that was quite a while back now......
    barftone's Avatar
    Apr 2005
    Bath, England
    Take out your brake pin and have a good close look to make sure it has not worn. Replacements don't cost much and as Kymmy said make sure it is greased with a high melting point grease. Also might be worth pushing out the piston and checking the seals.
  1. Rear Brake Pads
    By DaveS in forum XR
    Last Post: 09-07-07, 10:13 PM
  2. Rear Disk Brakes - help
    By Hammy in forum Dominator / FMX
    Last Post: 20-06-07, 05:21 PM
  3. XR250 Brake Disk, for less than £50?
    By sliderscraper in forum XR
    Last Post: 14-05-07, 02:34 PM
  4. brake disk price
    By taffy in forum Africa Twin
    Last Post: 23-01-07, 10:54 PM
  5. Disk Brake on a 1990 TA
    By Genisis300 in forum Transalp
    Last Post: 09-10-05, 10:37 PM
