Page 1 of 10 1 2 3 ... LastLast
Results 1 to 10 of 98
Thread: AT fork conversion finally started
    atgreg's Avatar
    Feb 2005
    Sydney , Australia
    Operation CR Kayaba fork has started. just to remind you, Im fitting up a 96 CR250 front end to my AT
    The CR stem is 4mm bigger in diameter than the AT stem
    Original CR stem
    Machined down to fit the AT bearings
    Cutting the threads for the nuts
    Done and the AT nuts fit, excellent
    The stem will be pressed back into the triple clamps tomorrow, then Ive just got to wait till the forks come back from being revalved and sprung and we can bolt it onto the bike and sort out the steering stops and a plate to mount the ignition and sort out some sort of front mudguard.
    boboneleg's Avatar
    Bristol
    Re: AT fork conversion finally started
    Nice work Greg, I've been looking forward to your conversion. keep us posted
    2003 Transalp
    2004 KTM 950 ADV
    1998 Suzuki DR350
    chronyx's Avatar
    Surrey, UK
    Same, looking forward to seeing how this progresses!
    cbrpaddy Guest
    It sure looks like you're going some great work there, I wouldn't have a clue where to even start. What's the advantage these forks will give you then, is it longer suspension travel ?
    atgreg's Avatar
    Feb 2005
    Sydney , Australia
    Quote Originally Posted by cbrpaddy View Post
    more travel, more rigid front end, far superior damping to AT forks even if they have emulators like my standard At forks
    atgreg's Avatar
    Feb 2005
    Sydney , Australia
    stem in the clamps !!!,
    atgreg's Avatar
    Feb 2005
    Sydney , Australia
    OK, sunday is D'day, we'll be swapping front ends, hopefully, if all goes well I'll have piccies of the new forked AT. Wish me luck !!
    Chad's Avatar
    wickford,essex
    quality
    Lucas's Avatar
    Lucas is offline Member
    Aug 2007
    Canada
    Hello I I put a fork of CRF, the problem was the weight of the motorcycle because the CRF weighs 110 kg and the AT 220 kg, I have of to return the fork at an assistant to put holds and new springs(competences) and to say to you preparations my couté dearer(more expensive) than the purchase of the fork and if you not made not the prépa the motorcycle guidonne
    Bonjour
    Moi j'ai mis une fourche de CRF,
    le problème était le poids de la moto car la CRF pèse 110 kg et l'AT 220 kg, j'ai du ramener la fourche chez un préparateur pour mettre des cales et des nouveaux ressorts et pour vous dire la préparations ma couté plus chers que l'achat de la fourche et si vous ne faite pas la prépa la moto guidonne
    [/IMG]
    atgreg's Avatar
    Feb 2005
    Sydney , Australia
    Lucas, the forks have been valved & sprung to suit the africa twin. What front mudguard did you use ??
  1. Respraying the bike has started...
    By skellem in forum Varadero
    Last Post: 03-10-07, 09:43 PM
  2. After I have started a new thread how do I change the title
    By Austin in forum Problems with the forum?
    Last Post: 12-04-07, 07:47 PM
  3. Getting it started-bike standing 1year+
    By teriyakimonkey in forum Transalp
    Last Post: 28-03-07, 08:23 PM
  4. ive started playing already.!!!
    By Chad in forum Chatter
    Last Post: 23-07-06, 12:17 AM
  5. what fork springs or fork mods?
    Last Post: 05-04-05, 08:13 PM
