Honda Trail Bike Forums
Go Back   Honda Trail Bike Forums > Honda Trail Bikes > Africa Twin
Reply
  #1 (permalink)
Old 17-01-08, 09:38 AM
R0vers's Avatar
BLUE 1999 xrv750x
Fitting the Baglux Tank Cover.
Finally!! - having waited 8 weeks - it has arrived....!!!!
There i was thinking it would be a piece of cake fitting it.....
1. does the airbox cover go under or over? - this would mean cutting 4 neat holes in the tank cover???
1. - where does the front adjustable strap go around?
3. - where does the rear adjustable strap go around?
4. - I am presuming that the cover will stretch and settle out over the next couple of weeks??? - as the fuel cap hole is oval and not round...
thanks in advance guys!
__________________
TLD2008 15.41
  #2 (permalink)
Old 17-01-08, 09:50 AM
Member
Re: Fitting the Baglux Tank Cover.
The Bagster tankcover is over the airbox cover. Not sure if it is the same with the Baglux.
  #3 (permalink)
Old 17-01-08, 10:39 AM
Raven's Avatar
" Nevermore "
Quote:
They are one and the same good sir . Bagster make them, Baglux distribute them.
r0vers, I can't help specifcally with fitting on an Africa Twin, but I can tell you that they do stretch out over the course of 2 weeks or so, moulding around the contours of the tank, and as long as you are careful not to overtighten straps at first, the petrol cap hole should stay circular . Dont forget that it is easier to fit if it has been left next to a source of heat for about an hour or so (not too close mind ), it makes it much easier to manipulate. Its also worth, over the course of the two weeks, slowly tightening the straps as the cover stretches and shapes, but ensuring that again they aren't being over tightened. I had one on my previous bike, only yesterday fitted one to my current bike, and have fitted them to several of my friends bikes this way and all has been well .
I hope any of my ramblings helped
__________________
:: 2007 XL650V Transalp :: with Honda Center Stand, Top Box & Panniers, SW Motech Engine Bars, Rugged Roads Chain Guard, Powerbronze Screen, Pyramid " Fenda Extenda ", Renthal Handlebar Brace, Garmin Zumo 400, Bagster Tank Cover and a Scottoiler
:: 1993 Nissan Sunny :: Miss Raven's new mode of transport, has two more wheels than the last one
  #4 (permalink)
Old 17-01-08, 10:49 AM
R0vers's Avatar
BLUE 1999 xrv750x
Raven,
Thank you for the heads up on this!!! i will re-adjust the straps as suggested....
__________________
TLD2008 15.41
  #5 (permalink)
Old 17-01-08, 10:55 AM
Raven's Avatar
" Nevermore "
Which direction is the hole going oval? If it's to the sides of the tank, then its the straps on the side that are pulling too tight, and conversly if its going oval towards the top of the tank, its the ones on the top and/or the bottom.
While I think of it, did you take the tank cover out of the box and let it settle for a while when you first got it? I only say this as when mine arrived Teusday it was in a very narrow box, and was kind of out of shape, so I put it on the back of a chair to spread it out for about 12 hours, and that got rid of a crease down the middle and the slightly elongated petrol cap hole.
It is most likely the straps but thought it was worth mentioning. Let us know if you get it sorted
__________________
  #6 (permalink)
Old 17-01-08, 11:01 AM
Generalissimo Tea Boy
Location: north Essex, I can see Suffolk from here with binoculars
I've had mine in continuous use for 8 years, they ride up with wear. Front strap I put under the headstock just behind the actual shaft, back strap I pass under the rear mounting plate (the bit the two bolts go through). Then I tension them so I can see the petrol cap. Then I fit the rubber straps to the underside of the tank (think I had to remove some trim off the tank for that.)
__________________
JANET STREET PORTER......
BURN THE WITCH!!!!!
2000 XRV750 (NO 3), I think I'm getting the hang of them now, must fit the centrestand before the back tyre wears out. Damn, the driveshaft bearing wore out first!
  #7 (permalink)
Old 17-01-08, 11:26 AM
R0vers's Avatar
BLUE 1999 xrv750x
"Front strap I put under the headstock just behind the actual shaft, back strap I pass under the rear mounting plate (the bit the two bolts go through)"
Thanks Yen.!!
i suspected this was the way to go.....!
I will have a tinker....
__________________
TLD2008 15.41
  #8 (permalink)
Old 17-01-08, 12:04 PM
Member
Quote:
Yen, how do the paint underneath look when you had it on for a long time? Does dust get under it so it scratches up the paint? I got at tank cover from my wife to Cristmas, and i'm considering to put vinyltape on the tank to protect it before fitting the cover.
  #9 (permalink)
Old 17-01-08, 12:06 PM
Twosheds's Avatar
Member
Oh Gawd.....Guess who ordered one of the these yesterday! same colour too....8 weeks!!
  #10 (permalink)
Old 17-01-08, 12:08 PM
Raven's Avatar
" Nevermore "
Quote:
Mine took 6 weeks to arrive. I think it's because they are hand made in France by Bagster and are then then sent over here to Baglux for dispatch.
__________________
Reply
Tags
baglux, cover, fitting, tank
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Baglux Tank Bag fitting question Steve C Bike Tech 6 16-07-07 07:28 PM
Baglux tank cover Austin Transalp 2 17-06-07 09:49 AM
Baglux Tank Cover Dim Reaper Transalp 10 12-03-07 09:47 PM
