Results 1 to 10 of 14
Thread: AT Not running right
    bazza's Avatar
    bazza is offline Senior Member
    Apr 2007
    Catterick, North Yorkshire
    Hi all im back again with another problem.
    While riding at about 3k revs and below the bike seems to miss a bit as if its not getting the right amout of fuel.
    But at higher revs it rides fine.
    Could this be the fuel pump.
    THANKS PEEPS
    Re: AT Not running right
    Could be a very very sticky choke, this has no effect at high revs but when warm the bike runs badly at lower revs. Check the two easiest to remove sparkplugs to see if they are sooty.
    GSPD750's Avatar
    Calgary, Alberta Canada
    Quote Originally Posted by bazza View Post
    THANKS PEEPS
    Year/model and miles? Original fuel pump?
    Steve C's Avatar
    England - landed in Yorkshire
    The AT has less low down grunt than might be expected for a 750 twin
    On my AT (25,000 miles, reg'd in early 01) I find that when trundling along it can become a bit hit and miss at revs much below 3.5k and it's best to change down. Not necessarily a fuel problem just that the engine is running out of puff and closing in on its stalling speed. Running the bike like that tends to make it less predictable and it can cough and splutter if I tweak the throttle and engine braking is less available too.
    !Boris!
    !Boris!!Boris!
    icenian's Avatar
    Jul 2004
    Votadinia
    I'd suspect the choke, and like Yen says it's easy to check as the plugs will be black and sooty.
    An AT ought to be OK down to about 2500rpm in the lower gears, though. It doesn't make much power but should be OK if trundling in traffic in 2nd gear, for example. If it won't do that I'd suspect a choke problem that isn't too bad yet. I think I had my AT for a whole year with a dodgy-but-not-too-bad choke before it became so bad I realised something was wrong and fixed it; I then spent another 2 years of it being a bit ropey on and off; then I disabled the choke and since then it's been smooth and sweet running ever since!
    Another thing that can happen at this time of year is carb icing. This affects running at low revs. It will usually appear after a few minutes at higher speeds, if you slow down and lets the revs drop. Revving the engine to keep it running works briefly (it;'ll get you to the hard shoulder, say) but the problem will affects the bike at progressively higher revs until it won't run at all. Stop the engine and after a few minutes it runs fine, as the engine heat thaws the carbs. It'll probably disappear with better weather (damp weather just above freezing seems to be the worst for it) and/or a tankful of better quality fuel. If it's really bad, Silkolene "Pro FST" sorts it completely.
    Last edited by icenian; 11-02-08 at 10:49 AM. Reason: I'm too stupid to remember what I was going to say
    Chad's Avatar
    wickford,essex
    hmm sounds like the choke to me as others have saidits not behaving like a fuel pump problem
    loftyjohn is offline Member
    Mar 2006
    Cannock,Staffs
    Hi
    Check out your battery?
    I had the occasional miss at low revs a couple of days latter I had a dead battery!
    Hosay Guest
    Bazza, mine (02 plate, 25k) has a similar problem.....holding it at about 75 mph in fifth it feels like it's slightly starving of fuel but open the throttle and it pulls clear.....
    battery connections are fine, no cack on the plugs so my next job is to try a new fuel pump...
    Jim.
    blacksoe is offline Junior Member
    Feb 2008
    west yorks
    THANKS PEEPS
    start at begining set tappets check plugs balance carbs somewhere in that order
    chronyx's Avatar
    Surrey, UK
    Quote Originally Posted by icenian View Post
    Has it ever refused to start in the properly cold weather you guys get up there?
  1. Running in Xl 700
    By daveXL700 in forum Transalp
    Last Post: 07-02-08, 11:10 AM
  2. running rough?
    By fairbrother1969 in forum Africa Twin
    Last Post: 18-06-07, 09:34 PM
  3. Running sweet as a nut!
    Last Post: 31-07-06, 07:05 PM
  4. running in
    By kev in forum Transalp
    Last Post: 20-11-05, 04:13 PM
  5. Running hot
    By Ashley in forum Africa Twin
    Last Post: 26-09-05, 07:02 AM
