Results 1 to 10 of 11
Thread: xrv650 1989
    burrich's Avatar
    burrich is offline Senior Member
    Rochester,Kent
    xrv650 1989
    Hi everyone having purchased my second XRV650 1989 last week,i need some help. The indicators are playing up Indicate left fine..flashing away. Indicate right,front one nothing....rear comes on and stays on Checked and replaced bulb,checked bulb holder and wires...after that i am abit limited with my electrical knowledge!! Hope you can help...
    Re: xrv650 1989
    It sounds very much like the front is not connected to the circuit, Check the wiring.
    Whealie's Avatar
    Lewisham, SE London
    Re: xrv650 1989
    Quote Originally Posted by burrich View Post
    The bike is completely shot. It is worthless. You'd have to pay to have it taken away. As a favour I'll come and collect it from you. Have the paperwork signed and ready. Honestly, I'm doing you a favour.
    burrich's Avatar
    Rochester,Kent
    Re: xrv650 1989
    Many thanks for your offer Whealie...but i am going to have refuse it ....sorry....
    Whealie's Avatar
    Lewisham, SE London
    Re: xrv650 1989
    It'll have to be a ride out together sometime then.
    Kjell Lindberg's Avatar
    Sweden
    Re: xrv650 1989
    Hi!
    Great! Another XRV650
    As for the non working indicator, I would check if the front indicator circuit on that side is okey.
    Usually the indicator circuit needs the right impedance to be able to produce the blinking effect, but typically the "blink frequency" will increase when the other bulb is out.
    Would you please supply us with a picture of your bike?
    By the way, there is one for sale in Sweden:
    http://www.blocket.se/vi/15141745.htm?ca=15_s
    BobA's Avatar
    BobA is offline xRv PiMp ;-)
    Sussex Riviera
    Re: xrv650 1989
    Pop the front fairing, or even just the screen off and trace the two wires from the indicator back to where the connect into the main loom.
    The earth bullet connector will go into a receptacle with the earth from the other inicdicator (i think) and I reckon where the bullet connectors go in they will be corroded/broken/dirty or just hanging out.
    15 minute jobs at the most!
    Good Luck
    BobA's Avatar
    Sussex Riviera
    Re: xrv650 1989
    OR, save yourself the hassle and let Whealie have it!!!
    burrich's Avatar
    Rochester,Kent
    Re: xrv650 1989
    Thanks for all your answers.....and Whealie,your not getting it and i will try and post a picture
    burrich's Avatar
    Rochester,Kent
    Re: xrv650 1989
    Whealie...and i would like to have a ride out some day
  1. Nx650, 1989
    By waynegrob in forum Dominator / FMX
    Last Post: 20-03-07, 03:50 PM
  2. buying a 1989 rd-03
    By hurbie in forum Africa Twin
    Last Post: 31-08-06, 06:59 PM
  3. First time buyer, XRV 650 1989. Help please.
    By cutepape in forum Africa Twin
    Last Post: 18-08-05, 08:52 AM
  4. 1989 Transalp mirrors
    By trunkfunk in forum Transalp
    Last Post: 22-07-05, 07:00 AM
  5. 1989 Transalp
    Last Post: 15-07-05, 09:39 AM
