About a year and a half ago I got one of those cheap battery chargers from lidl when they had their bike stuff on sale, and I've been using it to keep the battery on my 125 and the @T topped up while I haven't been using them.
When I let my little 125 battery run right down once, I noticed it took around 5 to 6 days to bring it back to life and recharge it (seems to have been fine afterwards), so it was obviously charging very gently. Wondering if it'd be possible to connect it up the the battery while it's on the bike, I dug out the manual and it does seem clever enough to do that. Was a bit nervous about trying it, but I've wired it up to my @T battery while it's on the bike and it does seem to be doing the trick very well. Keeps the battery topped up and stops the alarm draining the battery, and intelligently varies the voltage and turns itself on and off according to the condition of the battery, just like the more expensive optimate/optimiser type chargers seem to. Not bad for less than a £10er (think that's about what I paid for it).
I'm now thinking about wiring in some sort of connector to the side panel, and changing the crocodile clips on the end of the charger lead so I can quickly plug and un-plug it to keep the battery in tip top condition when I'm not using the bike, and to stop the alarm putting a drain on it, without having to go to the trouble of taking the side panel off each time.
I've got a lighter socket block (with 3 sockets in) that's ready to be wired up for powering gps etc. and my plan was to wire this in using a relay so they're only powered when the ignitions on, taking the positive feed from somewhere up near the front of the bike to save trailing wires back to the battery. My plan has been to mount this on the front of the bike somewhere up near the clocks.
I'm wondering if it might be possible to make this dual purpose, so it can be used for powering gadgets while on the bike, then I can simply stick a charger lead into it to keep the battery charged when I'm off the bike.
Would this mean that I'd need to have it wired directly the battery, or if I can still wire it into the loom at the front of the bike somewhere as I originally planned (might be a dumb question).
Also, I'm guessing I'll need to wire it in without a relay as I'll be wanting to charge it when the ignition is off.
Does this seem like a good idea, or would I be better getting a seperate socket that I can mount on the side panel and connect directly to the battery for this particular function, and then wire up the 3 way socket block I have at the front of the bike as originally planned using a relay to a live when the ignition is turned on somewhere. I notice that the optimate uses a block type connector rather than a cigarette lighter socket, so I'm wondering if a cig socket is up to the job as well (can't think of any reason why not but then I don't know a lot about electrics either).
As well as these questions I thought this might be an interesting thread for anyone who has one of those lidl chargers who didn't know you could do this with them as well (though best to carefully check the instruction manual to make sure it's the same one I've got and you can get away with doing that ofcourse if you're thinking of it). They were less than a third of the price of the optimates, and while I'm sure they're not quite as advanced, do seem to do a very similar job from what I can tell.
