Results 1 to 5 of 5
Thread: Hepco and becker pannier racks
    @lf's Avatar
    @lf
    @lf is offline Senior Member
    Sep 2007
    Norway
    If somebody has monted Hepco pannier racks on their bike,
    could you measure them. Lenght and height?
    I belive TT loops are somewhat the same size. So they could maybe also be measured?
    Have searched the net for some accurate measures but cant find it.
    I am going on a short trip abroad and plan to buy a pair.
    Just want to know it regarding transport/packing
    Thanks in advance
    @lf
    Apr 2007
    East Anglia-ish
    Re: Hepco and becker pannier racks
    Hi @lf i have them fitted. do you want the internal measurment that the boxes fit into?
    AND A BIG UP TO IBN BATTUTA
    ADVERTISE HERE.
    Absynth eye drops
    see things in a new way
    @lf's Avatar
    @lf
    Sep 2007
    Norway
    Hi
    Thanks for replying.
    Would like the outside size of the loops.
    Length and height.
    Belive the loops are the biggest part in the set?
    Mounts/struts are smaller?
    I have limited space in my suitcase and would like to know if i could fit them into it
    Apr 2007
    East Anglia-ish
    Ok @lf here goes the max vertical height is 220mm the max horizontal lenth is 350mm the two bars that run down to the rear footpegs for support are 470mm long and the bracing strut that connects the two hoops under the rear light cluster are 470 ish
    ADVERTISE HERE.
    Absynth eye drops
    @lf's Avatar
    @lf
    Sep 2007
    Norway
    Thank you!
    Saved my day!
  1. AT RD04 Hepco & Becker Pannier Racks
    By BobA in forum Africa Twin
    Last Post: 26-12-08, 06:53 PM
  2. Hepco & becker advice please
    By Sohoeasy in forum Africa Twin
    Last Post: 03-11-07, 03:41 AM
  3. Hepco and becker luggage
    By Pigglet in forum Mechanical Advice
    Last Post: 08-05-07, 07:56 AM
  4. Hepco & Becker for RD03
    By aikidimi in forum Africa Twin
    Last Post: 21-05-06, 06:22 PM
  5. Hepco & Becker pannier racks fitted
    Last Post: 02-04-06, 09:27 AM
