Results 1 to 6 of 6
Thread: Painting & engine question
    Santiago's Avatar
    Santiago is offline Santiago
    Feb 2008
    Cameroun
    Hello, I saw a lot of bikes with non standard paint, what is a good paint to paint plastics fairings of my Africa twin? is there any special paint for this kind of plastic, may be sound s...d but a friend of mine painted the plastics of his moto and 3 weeks after the paint start to break.
    Second, my engine make some explosions when is running and I close the throttle , I cleaned and checked the carburator, I changed the spark plugs and still the same, any answer to this problem??
    Cheers!!
    spicy mchaggis's Avatar
    spicy mchaggis is offline Living for the weekend
    Jan 2008
    lyme regis
    Re: Painting & engine question
    Quote Originally Posted by Santiago View Post
    my engine make some explosions when is running, any answer to this problem??
    Cheers!!
    engine explosions, i think its best you got a new one.
    (sorry for being off topic)
    Bolton, Lancs.
    Paint;
    there is a special primer for plastic.
    Explosions;
    A common cause is a leak on the exhaust joints, either at the head or the silencer joint areas.
    pxlpig is offline Senior Member
    Mar 2008
    CANTERBURY
    hi Yeah there is a plastics primer, you can get it from anywhere as long as it is suitable for plastics (should say on the tin or ask the guy at the counter) as this has a greater flexibilty in it as the plastics move/vibrate a lot when ridden (for paint to handle), best bet is to go to an auto body shop explain what you want to do and they will point you in the right direction for aerosols (if DIY or cost if they are to do it).......dont forget to use a laquer on any paint that will be metallic (preserves it better and makes the sparkle, sparkle more in the sun), also do not use acrylic laquer on anywhere where there may be fuel (it will melt the lacquer) for this reason you will need a 2K (trade name,....its made from two parts) lacquer unfortunetly this is only available at auto bodyshops as they need to apply it....has some seriously bad chemicals in there (when spraying they need a seperate airline to breath from)......hope this helps.
    2000, RDO7, Black, Arrow Exhaust, Black Powerbronze screen, Corbin Seat, Hagon Shock, Black Crash bars, Garmin Nuvi, and a Shoei Hornet.
    Santiago's Avatar
    Feb 2008
    Cameroun
    Paint;
    Explosions;
    Thanks a lot!!!
    Regards
    Santiago's Avatar
    Feb 2008
    Cameroun
    Quote Originally Posted by pxlpig View Post
    Thanks a lot
    Regards
    Santiago
  1. Painting engine cases
    Last Post: 29-08-06, 11:16 PM
  2. Question on Costs for Painting Bike
    By BlindPugh in forum Mechanical Advice
    Last Post: 23-08-06, 08:56 AM
  3. Engine question
    Last Post: 29-05-06, 11:59 AM
  4. Engine Bars question
    By High & Mighty in forum Africa Twin
    Last Post: 03-10-05, 07:03 PM
  5. Question on Costs for Painting Bike
    By BlindPugh in forum Africa Twin
    Last Post: 01-01-70, 02:45 PM
