Page 3 of 6 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 60
Thread: RD04 Rattle
  1. #21
    c13tay's Avatar
    c13tay is offline Senior Member
    Standish, Lancs
    Re: RD04 Rattle
    The plot thickens !!
    Just been into my local Honda dealer.
    Chief mech there came out and had a listen.
    He doensnt thinks it cam chain or tensioner
    he doesnt think its valve clearances, although he thinks they may need adjusting
    he said, tappets would be noisy all the time
    He said cam chain would be audible at tickover
    He thinks it may be resonance or something somewhere vibrating as it is strange that the noise comes on at a given revs
    Suppose in one way thats good news given what he quoted me for doing cam chains !!!!!!
    Im getting frustrated now !!!!
    kennymact's Avatar
    Sep 2006
    christchurch/newzealand
    Re: RD04 Rattle
    what about the speedo cable drive components....my 10 cents worth.....
  4. #23
    c13tay's Avatar
    Standish, Lancs
    Re: RD04 Rattle
    does it wen bike is at standstill so dont think its speedo related.
    noticed one interesting thing last night.
    Doesnt seem to do it as much when the bike is on side stand compared to mainstand
    Could this be an oil or oil flow issue ???
    blocked oil filter maybe not letting enough oil through ???
    oil pump ?
    clutching at straws I know but there you go !!
    that fed up with it, I thought stuff it and went for a long ride on it last night !!!
  5. #24
    fatowl's Avatar
    May 2006
    Near Exeter, Devon
    Re: RD04 Rattle
    sounds (no pun intended) like it could be piston slap. That sounds like a metalic 'flutering' under low load, goes under load. I guess it would be unusual at only 30k miles though.
  6. #25
    c13tay's Avatar
    Standish, Lancs
    Re: RD04 Rattle
    Having read everything I can on these things recently, I had thought about that too but discounted it due to mileage - you never know though !!
    Having never heard piston slap I dont know !!
    Also, having read a bit about it would this not tend to go away at least a little when the engine is hot due to expansion. ??
    My noise is there hot or cold
  7. #26
    BobA's Avatar
    BobA is offline xRv PiMp ;-)
    Sussex Riviera
    Re: RD04 Rattle
    MMmmmm, being on the sidestand affects it?
    1) Is it different if the clutch is in or out? Clutch basket wear maybe?
    2) Could it be a foreign object in the crankcase?
    3) Any chance theres a foreign object in the airbox?
  8. #27
    c13tay's Avatar
    Standish, Lancs
    Re: RD04 Rattle
    Morning Bob
    Same with clutch in or out
    Airbox clear
    Suppose could be foreign object in crank case
    Thought id cured it last night - rear cylinder manifold bolts were loose ish. tightened them and the noise seemed to go.
    stood the bike up took it round the block and noise returned. thats how I noticed that the noise doesnt seem as bad when its on the sidestand
    Thanks for your input Bob - its much appreciated
    Chris
  9. #28
    BobA's Avatar
    Sussex Riviera
    Re: RD04 Rattle
    Yeah, I mentioned the copper O rings between the cylinder heads and header pipes before.
    They are in there aren't they? and also, the exhaust port and copper rings are a different diameter on the front & rear cylinders. Get the wrong ones, or get them the wrong way round, and you'll definitely get gas escaping at that joint. Just another idea.
    Morning by the way!
  10. #29
    fatowl's Avatar
    May 2006
    Near Exeter, Devon
    Re: RD04 Rattle
    if touching the exhaust has had an effect, what about the join between header pipe and silencer? Dunno about the TA, cos i've not been in there yet, but there's usually a bit of something like asbestos packing etc. has that disappeared? (there are a few joins in the TA exhaust system).
    Have you tried using a screwdriver as a stethascope to try and pin down where the noise is coming from?
  11. #30
    c13tay's Avatar
    Standish, Lancs
    Re: RD04 Rattle
    Yes, tried the old screwdriver thing - didnt help much
    Seems im going to have another night in the garage tightening, untightening and generally scratching my head !!!!
    Instead of just tightening, might start taking things off now - at least its something different to do
    Not only is it annoying me but the wife is getting annoyed as well now - all those littel jobs that need doing are taking second place to this bloody rattle !!!!
    She should be grateful - at least im not in the pub !!!
  1. Replies: 0
    Last Post: 13-02-08, 08:46 PM
  2. Replies: 5
    Last Post: 12-05-07, 06:34 PM
  3. Rattle...worried
    By jollyrodger2005 in forum Dominator / FMX
    Last Post: 16-04-06, 01:24 PM
  4. Engine Rattle
    By DaveS in forum Africa Twin
    Last Post: 12-01-05, 06:55 PM
  5. rattle
    By rob4 in forum Africa Twin
    Last Post: 16-05-04, 01:41 PM
