Page 1 of 6 1 2 3 ... LastLast
Results 1 to 10 of 60
Thread: RD04 Rattle
    c13tay's Avatar
    c13tay is offline Senior Member
    Standish, Lancs
    RD04 Rattle
    Got a rattle on my RD04
    It done about 30k miles (well thats what the speedo says !!)
    at standstill -
    No rattle at tickover
    Just a hind of a rattle when engine is reved (at the rev peak)
    on the move -
    No rattle under acceleration
    Semms to rattle when just off load - say when tryting to hold a constant speed.
    Metallic rattle
    Thinking this is cam chain / adjuster / tensioner ??
    Anyone agree or have any other ideas ??
    thanks
    Chris
    mal's Avatar
    mal
    mal is offline Senior Member
    Aug 2004
    GLASGOW
    Re: RD04 Rattle
    Hi Chris, I would check the sump guard is mounted properly, the clutch on these bikes rattle when cold it normally goes away when the engine warms up though
    c13tay's Avatar
    Standish, Lancs
    Re: RD04 Rattle
    Thanks for the reply Mal
    Sumpguard is ok.
    If it was timing chain would it rattle at tickover ??
    mine doesnt -
    mal's Avatar
    mal
    Aug 2004
    GLASGOW
    Re: RD04 Rattle
    Hi Chris yes possibly, hopefully someone else will advise
    R0vers's Avatar
    R0vers is online now BLUE 1999 xrv750x
    Mar 2007
    South London/Somerset
    Re: RD04 Rattle
    Quote Originally Posted by c13tay View Post
    at standstill -
    on the move -
    Metallic rattle
    thanks
    Chris
    Quote Originally Posted by mal View Post
    Chris,
    is it definatly comming form the engine do you think? - loose chain knocking on the swingarm - or bearings?
    TLD2008 15.41
    c13tay's Avatar
    Standish, Lancs
    Re: RD04 Rattle
    As far as i can tell its coming from the engine.
    It a very rapid metallic ticking.
    by carefull adjustment of the throttle I can ride without it doing it.
    the higher the revs the faster the tick (i think)
    perfectly quiet at tickover
    Just looking for ideas so I dont end up spending a fortune doing jobs which I think may cure it but dont !!!
    The Pheasant is offline Senior Member
    Surrey
    Re: RD04 Rattle
    Loose screws on the exhaust heat guard? The one on the silencer does this if the little locating tangs get bent.
    c13tay's Avatar
    Standish, Lancs
    Re: RD04 Rattle
    thanks for all the suggestions
    Its definately engine .......... I think
    Oh well...... ill just have to bite the bullet and take it in - see what my local mech says
    c13tay's Avatar
    Standish, Lancs
    Re: RD04 Rattle
    Well took the bike to my mechanic last night.
    "thats a strange noise" he said
    He said it could be cam chain related but he doesnt think so at this stage.
    He has suggested initially setting up the tappets, balancing carbs etc
    Hes going to do that lot next week so will see how it goes.
    As an aside he said he did an engine swap on an @ last year whre he replaced the 750 with a lump from a firestorm. Now theres an idea !!!!
    By the way - if it does turn out to be something more serious (or more expensive !!!!) then there willl probably be an RD04 for breaking so all you RD04 lot, on your marks ..............................
    Zenarchy's Avatar
    North East UK
    Re: RD04 Rattle
    First dibs on your nose fairing sub-cowls if they're in good condition
    Seriously though, hope it doesn't come to that. I think tappets can make that sort of noise and they're quite easy to sort out so it might be something simple like that with a bit of luck.
  1. Replies: 0
    Last Post: 13-02-08, 08:46 PM
  2. Replies: 5
    Last Post: 12-05-07, 06:34 PM
  3. Rattle...worried
    By jollyrodger2005 in forum Dominator / FMX
    Last Post: 16-04-06, 01:24 PM
  4. Engine Rattle
    By DaveS in forum Africa Twin
    Last Post: 12-01-05, 06:55 PM
  5. rattle
    By rob4 in forum Africa Twin
    Last Post: 16-05-04, 01:41 PM
