Results 1 to 7 of 7
Thread: Spark plugs
    paul_r is offline Widget
    Mar 2006
    East London
    Spark plugs
    An old subject but something I cant find information on atm.
    When removing the fuel tank to do the spark plugs, do you have to remove the 3 tubes, i.e. fuel tube, air vent tube and the overflow tube?
    Are these easy access from the left or the right?
    Is there enough room to just wiggle the tank out the way to access the spark plugs?
    Hope someone can give me the idiot guide to this and save my sanity
    Kind regards
    Paul
    Sherky's Avatar
    Sherky is offline Junior Member
    Jan 2008
    bucharest
    Re: Spark plugs
    hello, you don't have to remove any tube, just use the right sparkplug honda tool which has a unique shape .. that's all ...
    Mar 2006
    East London
    Re: Spark plugs
    cheers sherky, no joy at the moment , no room to get under the tank and work, will have a proper look at the weekend when got more time
    Paul
    Sherky's Avatar
    Jan 2008
    bucharest
    Re: Spark plugs
    anyway you will have to take the tank off
    doglegdon's Avatar
    Southern Philippines
    Re: Spark plugs
    Quote Originally Posted by Sherky View Post
    seconded, for sure!
    2008 KTM 990 Adventure S
    Gaz's Avatar
    Gaz
    Gaz is offline ... and this is me
    North Wales
    Re: Spark plugs
    Hi Paul
    I’ve successfully changed all 4 spark plugs a number of times and have never removed the tank or any pipes. Mine is a RD07a so not sure if other models are the same. You do have to raise the tank at the back using the tank-lifting-up-tool that Honda supply and hide underneath the seat in order to access the 2 rear plugs. I can also remove the 2 front plugs without removing any fairing panels. The Purpose-made Honda spark plug tool is essential though, as Sherky points out. To be honest it was a bit fiddly to begin with but as soon as that tool latches on to the plug you know it’s in the right place and I whizzed them out in seconds.
    Good luck
    Gaz
    Merkado is offline Member
    May 2008
    Isarel
    Re: Spark plugs
    Is that sparkplug honda tool is the tool provided with the original tool kit provided? (the one under the seat)
    Cheers...
  1. Getting out the spark plugs ...
    By idefix in forum Transalp
    Last Post: 22-01-08, 09:17 PM
  2. spark plugs
    Last Post: 13-09-06, 10:53 PM
  3. SPARK PLUGS
    Last Post: 05-09-06, 01:26 PM
  4. spark plugs
    By P&J in forum Africa Twin
    Last Post: 10-07-06, 10:35 AM
  5. spark plugs
    Last Post: 25-05-05, 06:46 AM
