I've been having hastle with this since I took it off to clean up the bike when I first got it. My bike's and RD04.
When I try to fit the sprocket cover back, and tighten the bolts that hold it in place, it seems to distort the plastic cover and pull the bottom part towards the chain (where the chain comes out of the cover at the bottom).
I've had it off again recently and noticed some wear marks on the inside of the plastic cover in that area (like the side of the chain is rubbing against it). I put some black silicone blobs on the end of the pins on the chain and they've worn off so it seems to be rubbing the pin ends on the chain.
I must have spent hours trying to sort it so far. It seems OK until I tighten the bolts up then no matter what I try it always seems to pull the plastic back in towards the chain at the bottom.
I'm guessing it's something to do with that metal retainer thing that runs around the inside of the cover (it's an rd04). I've tried bending it a little, adding washers to the back of it (so it keeps the guard a little further out) but still the same problem.
Was wondering if anyone else had ran into this problem and there's something simple I'm missing?
I'm at the stage now where I'm stuck and not sure what else to try (apart from perhaps trying to buy another sprocket cover and metal retainer but there's no guarantee that that'll be any better ofcourse).
Any ideas?
