Results 1 to 8 of 8
Thread: Bike died
    Robmac is offline Junior Member
    Oct 2006
    Kent
    Bike died
    Can anybody help
    I was travelling down the m20, doing approx 80mph, when my AT just lost all power, pulling into the hard shoulder, i tried bumping, nothing!. Stopped on the hard shoulder. allelectrics worked ie lights indicators etc, but electric start would not work. Called AA they turned up visually checked everything i had already visually checked. then kindly gave me and my AT a lift to Laguna in Maidstone and then very kindly gave me a lift home.
    Can anybody help diagnose my problem, hopefully saving time and money at Laguna
    Robmac
    raymo's Avatar
    aberdeenshire Scotland
    Re: Bike died
    to bog like that...
    its likely fuel , ( fuel pump )or a fuse... hopefully real cheap..
    or an alien beamed your engine internals away?
    GSPD750's Avatar
    Calgary, Alberta Canada
    Re: Bike died
    Quote Originally Posted by Robmac View Post
    Can anybody help
    Robmac
    Have you checked the fuse box. Circuit 'D' is 10 amp and works the starter, fuel and ignition.
    xrv_jim's Avatar
    Jul 2004
    Northern Cumbria
    Re: Bike died
    Rob, you might want to have a look at this thread. The same thing happened to my AT last weekend in very similar circumstances.
    Jim
    '95 R1100GS
    '80 XT250
    BobA's Avatar
    BobA is offline xRv PiMp ;-)
    Sussex Riviera
    Re: Bike died
    Robmac
    Laguna have got it now, but I'd suggest checking the (30 amp I think) big master fuse, which is located under the connector on top of the started solenoid.
    Moisture gets in there, they start corroding, the resistance becomes high between the fuse and it's contacts, they heat up, melt, and do all sorts.
    A quick visual check will take a couple of minutes, but while you're doing it, clean it up anyway.
    Good Luck
    Oct 2006
    Kent
    Re: Bike died
    Thank you for your help, it was the main fuse
    raymo's Avatar
    Re: Bike died
    cool... nice and cheap hope you now carry a spare and know where it is
    r
    j's Avatar
    j
    j is offline SHW'MAE BUTT
    Apr 2006
    Re: Bike died
    but what caused the fuse to go????? 30amp fuses dont just go????
  1. The Bitch has died RIP
    By SteveWilko in forum Chatter
    Last Post: 03-04-08, 03:59 PM
  2. HELP!!! My Twin died on the way home
    By xrvrussb in forum Africa Twin
    Last Post: 29-10-06, 05:02 PM
  3. Domi died on me??? : - (
    By The Cosmic Lawnmower in forum Dominator / FMX
    Last Post: 21-06-06, 10:54 PM
  4. Dog died....
    By ChrisH in forum Chatter
    Last Post: 04-04-06, 06:59 PM
  5. And then it just died...........
    By Dilbert in forum Africa Twin
    Last Post: 08-06-05, 02:09 PM
