Results 1 to 6 of 6
Thread: tom tom rider
    Oro's Avatar
    Oro
    Oro is offline Senior Member
    Feb 2005
    Hereford, England,UK
    tom tom rider
    just brought a tom tom rider for my @
    a few questions.
    i want to wire it straight to the battery.should there be a fuse.
    what have other people done with the wires going to the battery.has anyone fixed connectors on them or just wrapped the wires round the battery screw and tightened screw up.
    if u know what i mean tom tom owners
    any pics would be good with location of tom tom on handlebars a installation
    many thanks to u all
    Apr 2007
    East Anglia-ish
    Re: tom tom rider
    Hi oro its a smart move to fit an inline fuse as if your reg/rec goes its last mission is to destroy as many electrical components as it can so 75p will save a lot of bother.and also fit connectors to your wire ends at worst it is somthing less to consider if you have a wiring fault on your bike.
    AND A BIG UP TO IBN BATTUTA
    ADVERTISE HERE.
    Absynth eye drops
    see things in a new way
    BobA's Avatar
    BobA is offline xRv PiMp ;-)
    Sussex Riviera
    Re: tom tom rider
    Oro
    Mel is right, make sure you put an inline fuse in series with the + wire.
    You can buy in-line fuse holders for blade fuses, or the old glass style ones in Halfords, and if you do have an electrical problem it will be the best couple of quid you spent. The Rider should tell you what fuse to fit, but if not use the smallest value you can get away with (that doesn't keep popping).
    I wired my Rider into the sidelight circuit, as I always ride with my lights on anyway, and it's just inches away from where the TomTom will be, and it does give you the option of switching it off (with the lights) if you want to.
    Good Luck
    mal's Avatar
    mal
    mal is offline Senior Member
    Aug 2004
    GLASGOW
    Re: tom tom rider
    I have a car Tom Tom, on the power plug there is a tiny 2 amp blade fuse , so I would install a 2 amp fuse to be on the safe side.
    raymo's Avatar
    aberdeenshire Scotland
    Re: tom tom rider
    I power my GPS from the +ve feed to the front brake light switch.. that way its protected by an existing fuse, and cut off when the ignition is off, and the supply is a few inches away.. so no need to take seat / tank off to run wires
    cheers
    Ray
    Oro's Avatar
    Oro
    Feb 2005
    Re: tom tom rider
    thanks everyone
    im going to do a proper job and wire it to the fuse box so theres only power there when the ign is on.
  1. Rider Power
    Last Post: 22-11-07, 06:06 PM
  2. TomTom RIDER
    By Robster in forum Mechanical Advice
    Last Post: 16-05-07, 04:57 PM
  3. Rider or owner???
    By squirrelciv in forum Chatter
    Last Post: 02-12-06, 07:46 PM
  4. New rider
    By steve_b in forum Transalp
    Last Post: 28-10-06, 11:58 AM
  5. Tom tom rider
    By pete07bikes in forum Varadero
    Last Post: 24-08-06, 10:36 PM
