Results 1 to 7 of 7
Thread: Front Sprocket Cover
    JamesJoyce is offline Junior Member
    May 2008
    Midlands
    Hi guys,
    I'm currently trying to remove the front sprocket cover and it's proving to be more difficult than I think it should be. I've removed the gear change lever and also the top retaining bolt, however I'm having some problems getting a spanner or socket on the lower bolt. I was thinking of removing the bash plate to make it a bit easier to access. I was wondering if it necessary to do this as I have discovered that a few of the retaining screw heads have been rounded and will be very difficult to remove. Any advice would be greatly appreciated.
    Dave
    Re: Front Sprocket Cover
    Quote Originally Posted by JamesJoyce View Post
    Hi guys,
    Dave
    The bash plate is only held on with 4 12 mm bolts, 2 high up the front, one by the sprocket cover and one underneath by the right hand footrest, ignore the crosshead screws they hold the 3 pieces together. I use a small thin walled 8 mm socket or a T-bar socket on the lower sprocket cover bolt as it's sitting in between a few cables etc.
    BobA's Avatar
    BobA is offline xRv PiMp ;-)
    Sussex Riviera
    OR, if you're a real lazy-ass like me, and you don't want to attempt removing a crud covered bashplate, you can just undo the one bolt near the sprocket cover, and lever the bashplate down a bit so you can get a 8mm socket on a long extension to undo the lower sprocket cover bolt.
    Yep, I'm a total bodger sometimes!
    May 2008
    Midlands
    Thanks for the tips. The bash plate is now off and now I just need to wait for my mate to get home so I can borrow his socket set.
    Dave
    GSPD750's Avatar
    Calgary, Alberta Canada
    8mm nut driver as in the following or 8mm socket on a 1/4" drive extension.
    FatFergie's Avatar
    Mar 2006
    If your bolt heads are rounded off don't put them back in, replace with similar or allen heads.
    boboneleg's Avatar
    Bristol
    Spot-on Bob that's what I do as well
    2003 Transalp
    2004 KTM 950 ADV
    1998 Suzuki DR350
  1. Sprocket cover fitting problem
    By Zenarchy in forum Africa Twin
    Last Post: 27-05-08, 07:57 PM
  2. Front sprocket
    Last Post: 14-08-07, 10:39 AM
  3. Front sprocket
    By Kerr in forum Transalp
    Last Post: 21-07-06, 08:07 PM
  4. Front sprocket
    By Kerr in forum Africa Twin
    Last Post: 16-07-06, 09:30 PM
