Results 1 to 3 of 3
Thread: Clocks
    greg_milne is offline Member
    Feb 2008
    Glasgow
    Clocks
    Is it possible to strip the clocks to bits? Thinking of taking mine apart to see if anything looks dodgy with the sensor for the trip computer. I soldered in the link today for the km/h and it works up to about 40km/h then it just goes back to zero until you slow down again, the same with the trip counter, it only counts miles when going slow.
    Has anyone tried to take the clocks apart?
    Greg.
    kennymact's Avatar
    Sep 2006
    christchurch/newzealand
    Re: Clocks
    I have an rdo4 1990 and i stripped my tacho by carefully prising off the outer case,fixed the broken tacho counter and pressed it back on,hope it works for you....kenny
    Feb 2008
    Glasgow
    Re: Clocks
    Cheers Kenny, think mine mite be different tho as ive got an RD07. Will give it a try tho.
  1. alternative clocks
    By jabba in forum Transalp
    Last Post: 30-04-08, 02:36 PM
  2. clocks / illumination
    Last Post: 06-06-05, 09:03 AM
