new battery,new plugs,but no lights,power or any electrics.please help
Also might be the ignition barrel. Try hot wiring it by unplugging the ignition barrel and connecting the terminals as if the switch was on to check(wiring diagram will help there,connectors under the tank somewhere).
As post #2 mentions...the 30amp (main) fuse is most likely blown. May have shorted something during the battery installation. Did you see sparks?
