Hi,
I checked my output drive shaft earlier today and have a nasty feeling that it may need some attention in the near future. I don't think there is a problem with the bearing as there is very little lateral or radial movement, the splines, however, are looking very worn. I have compared the condition with those detailed in previous threads where the diagnosis has not been good. Unfortunately, mine look very similar to these and are shown below :
I have read a number of threads on this issue and have noted some temporary solutions to this problem, such as welding the sprocket to the shaft, or welding on 'new' splines. As I am planning a RTW tour on my AT (1990, 43k miles) in around 12 months time I thought a replacement part , rather than a fix, would improve my chances of completion.
I understand that replacing the output shaft is one of the more challenging tasks, but (at the moment) I am thinking about giving it a go myself to try and save some money for the trip and also learn a bit along the way. After some initial research it seems to me that the cost of parts is going to be around £200 and consists of mainly of the shaft itself and various gaskets.
Do you think that £200 for parts sounds realistic ? Are the parts difficult to source ? I've looked on ebay, wemoto and davidsilver and have yet to see an output shaft. How long do you think this type of overhaul would take ? Am I crazy to even contemplate starting this ?
Dave
happy days.i thought about rings and bearings or full rebuild but everything else inside was in perfect order,at 60000miles still looks brand new.these really are bullet proof machines!
