Results 1 to 10 of 11
Thread: how do i fit aftermarket fuel pump??
    camnz is offline Member
    Feb 2008
    cornwall
    im in the process of putting my AT back togeather again and have replaced the original pump with a facet pump the same as sold on this site.i started buy pluging the wire into the original plug from the old pump but when i try and start the bike it blows fuses??have tried with the wires round both ways but no luck.does anyone know if i have to maybe find another + source and earth it to the bike??HELP
    Mutley's Avatar
    May 2004
    Top of the hill
    Re: how do i fit aftermarket fuel pump??
    Sounds pretty bad camnz
    Looks like an auto electrician if it's blowing fuses like that
    Good luck
    Stormforce8's Avatar
    Dec 2005
    New Forest - Hampshire-on-Sea
    According to the fitting instructions here - you should be able to utilise the existing wiring................so if it's blowing fuses it sounds like you have a short somewhere.
    I'm assuming that with your original pump the fuses remained intact and it was only after you installed the facet that the fuses started to blow? If this is the case then it sounds pretty localised. Check the connections again and see if there is any break in the wire or bare wire showing.
    Incidently, exactly which fuse is blowing?
    Stormforce8 SmugMug gallery
    Rugged Roads
    Current stable.............
    Feb 2008
    cornwall
    its the fuel/ignition fuse that keeps goin,the old pump was fine but for some reason the facet blows them.ive wired it directly to the fuel cut off relay but when the key is on so is the pump.not a big prob as there seems to be no fuel squirting out of anywhere so maybe ill try it on a run and see??
    GSPD750's Avatar
    Calgary, Alberta Canada
    Ok..2 wires went to the OLD pump. One is GREEN...this is the ground wire and this GREEN wire splices to the BLACK wire on the NEW Facet which is also ground.
    The other wire going to the OLD pump has double colours and is BLUE/BLACK and this wire splices to the RED power wire of the NEW Facet pump. This BLUE/BLACK wire is power and leads to the fuel cutoff relay. Sounds like you have them crossed somehow...or your fuel cutoff relay is fried ??
    sunnybrook's Avatar
    sunnybrook is offline Timid biker
    Mar 2008
    Edinburgh, UK
    Where exactly is the fuel pump's little connector? I was poking around under the fuel tank most of this evening with a mirror and spotlamp, and I couldn't see it anywhere, much less disconnect it to start checking the pump and relay, much much less replace the pump itself.
    Does it have to be a tank-off job? I only filled the thing up the other day.
    GSPD750's Avatar
    Quote Originally Posted by sunnybrook View Post
    Yup, tank off. In the vicinity of the cross member of the frame at the back end of where the tank would be. Just above where the petcock would be and wrapped in tape I believe. Only real way to find this connector is to follow the 2 wires from the fuel pump itself.
    steinberg's Avatar
    steinberg is offline Commuter Extraordinaire
    Nov 2006
    East Kent
    Why not just cut the OEM supply cable and crimp on some bullet connectors & shrink-wrap. Then it's easy to remove the OEM pump without having to access the hidden connector block. And it also makes connecting a new pump easy
    '02 XRV750
    '03 DR-Z400
    sunnybrook's Avatar
    Mar 2008
    Edinburgh, UK
    Quote Originally Posted by steinberg View Post
    Why not just cut the OEM supply cable and crimp on some bullet connectors & shrink-wrap. Then it's easy...
    I came to precisely the same conclusion this morning. I'm assuming, of course, that the wiring is all intact, so I'll at least be better able to attach my multimeter.
    Sorry camnz, I hijacked your thread!
    Feb 2008
    cornwall
    no worries sunnybrook i think im sorted??hooked up to the cut off relay seems to be working ok,will see i guess
    Last Post: 14-03-09, 09:27 AM
  2. Aftermarket Fuel Tank affects on Insurance!
    Last Post: 13-04-07, 12:48 PM
  3. fuel pump
    Last Post: 14-01-07, 07:21 PM
  4. Fuel pump
    Last Post: 07-07-05, 11:55 AM
  5. AT fuel pump
    By sa6andy in forum Africa Twin
    Last Post: 11-05-05, 01:35 PM
