Yesterday morning - in the rain - I turned on my ignition (RD07), the trip meter came on briefly, then shut off. Now it won't start.
I've checked and changed the main 30a fuse on the starter relay behind the LHS panel, and the one labelled ingition in the main fuse box, though both looked fine . No result.
My headlight works when I turn on the key - but none of the warning lights, or the rear light. The indicators don't work except on the alarm circuit - so it arms and disarms.
Am I missing anything obvious, or is it likely that there is a broken circuit somewhere - in which case I will have to get someone in to find and fix it.
The only good thing is that at least I was at home when it happened!
thanks
Richard
