Results 1 to 2 of 2
Thread: Loud noise of leaking spark at HT coil!!
    ABZ's Avatar
    ABZ
    ABZ is offline Member
    Sana'a-Yemen
    Finally,the queen is roaring after the battle i had with it !!!
    I was repairing the bike at sun set and it was the best time to see a leaking spark and it produced a loud noise. it was at the front HT coil sparking with the front cylinder's conical air filter. What is the cause of the spark and how can it be avoided??
    GSPD750's Avatar
    Calgary, Alberta Canada
    Re: Loud noise of leaking spark at HT coil!!
    Simple. Replace the HT lead or coil...if damaged. You could silicone the area for a qwik temporary fix.
  1. Loud engine noise
    By riils in forum Mechanical Advice
    Last Post: 11-06-07, 09:19 PM
  2. switch on coil
    Last Post: 30-08-06, 06:42 PM
  3. NX650X coil
    By shrekka in forum Dominator / FMX
    Last Post: 07-08-06, 07:28 AM
  4. Coil, Starter Motor, Rectifier...all of the above?!
    By Robster in forum Africa Twin
    Last Post: 27-02-06, 05:48 PM
  5. Loud Engine Noise
    By mickskelly in forum Africa Twin
    Last Post: 31-10-04, 11:15 AM
