Results 1 to 10 of 13
Thread: Help: Need a part
    Palmer's Avatar
    Palmer is offline Senior Member
    Oxfordshire
    Thumbs up Help: Need a part
    Ok guy's i hope Mel will be along soon, but basically he has said i can have his Scotoiler as long as i find a "bung" where the pressure comes from that powers it.
    I think a small tube attaches to the Enguin and as this will be removed we need the original bolt or whatevere comes in it as standerd.
    Cheers Ed
    Re: Help: Need a part
    Quote Originally Posted by Palmer View Post
    Cheers Ed
    Depending on the bike it is coming from you could always swap the vacuum pipe.
    On the TA it is powered by the fuel vacuum pipe, using a T piece.
    Palmer's Avatar
    Oxfordshire
    Sorry mate it's coming from a @t Rd07 i think
    You could try a dust cap from a brake bleed nipple.
    Whealie's Avatar
    Lewisham, SE London
    May have not thrown it away but I fitted a new reservoir using the existing pipes so may still have the stuff. Will search the garage.
    Palmer's Avatar
    Oxfordshire
    Cheers mate, obveusly money involved!
    Bolton, Lancs.
    Tech data;
    Microfisch;
    XRV750 S;
    block E-2-1 rear cylinder head.
    15 --- part number - 90089 - mn8 - 000 x1
    20 --- part number - 90452 - 323 - 000 x1
    Order from Lings 01379 853213. next day delivery (normally).
    Easy
    Palmer's Avatar
    Oxfordshire
    Cheers mate
    Apr 2007
    East Anglia-ish
    Cheers Len/wheelie/stumpyfingers bloomin yoof wouldent look it up, just went straight for the easy option, regards mel
    AND A BIG UP TO IBN BATTUTA
    ADVERTISE HERE.
    Absynth eye drops
    see things in a new way
    GSPD750's Avatar
    Calgary, Alberta Canada
    Scottoiler company is in your backyard.
    http://www.scottoiler.com/pc/Motorcy...In_Spigot.html
  1. Part Numbers
    By RainMan in forum Transalp
    Last Post: 08-06-07, 10:29 PM
  2. The Worlds gone mad - Part 2
    By alpslapper in forum Chatter
    Last Post: 02-03-07, 06:36 PM
  3. Name that part!
    By Robster in forum Africa Twin
    Last Post: 24-09-05, 10:44 AM
  4. Indicators - part two
    By DM in forum Africa Twin
    Last Post: 14-10-04, 05:55 PM
