Re: Chain tool
Originally Posted by
Jeff Kirby
Hi members,
Recently decided to change my chain - removed the old and bought the new - didnt think
about the tool required to get the new one on!
Hi....just put a new 42t rear sprocket on my @ which meant taking a link out....although a riveting tool is preferable I have never had to use one...
I used an angle grinder to remove the old rivet ends and split the chain...used a brand new DID 'rivet' link to re-join the chain....used the supplied grease, assembled the 'o'ring seals, plate etc....then used a centre punch to spread the rivets (punching against a lump hammer on the other side to absorb the shock)....the DID links come with a shallow hole down the centre of the rivet on the side you have to 'spread' with the punch.....check the new link is free (not stiff) and away you go...if you can't source a local tool, I hope this helps...
01 XRV750 Africa Twin. RWB
Dynojet+Airbox Mods, Heated Grips, Scottoiler, MRA Varioscreen, Motad Desert Bars, Autocom Kit6, Garmin Zumo 400, Kenwood B2B, Mitchelin Anakees.
