Thanks for that StumpyFingers
I got the lights working and it works great. I connected the brown to green/yellow and blue to green.
Here's some tips that may be useful to anyone fitting one of these kits...
1. The instructions are useless and mine was missing some sheets but they can be found
here if you need them. It's missing the page about connecting the wires but that is explained here (if you really want this page let me know and I will scan it and post it up).
2. When fitting the lights into the box, be very careful because the bulbs break off very easily, I broke one of the them
but luckily I had a spare as there was already a (broken) brake kit in the top box from the previous owner..
3. The wire connectors that come with the kit are not very good at all. They look good and seems like a smart idea but the clamp is supposed to strip just enough of the insulation so that the connection is made but I had to open the connectors and remove some insulation manually because it hadn't made sufficient contact. I think the best option would be to get proper electrical connectors from a motor or hardware store
4. The connector for the box was a little lose and gave an unsteady connection so added a bit of extra rubber around the base of the connector to make it steady and it worked perfectly.
5. Don't be a dumbass like me and install all the wiring in top box until you have fitted the connector into the base of the topbox. The base connector has to fitted from the outside of the box before the wiring..
Cheers,
Slanty
