Results 1 to 8 of 8
Thread: RD04 sprocket sizes
    BobA's Avatar
    BobA is offline xRv PiMp ;-)
    Sussex Riviera
    RD04 sprocket sizes
    OK people, I know a few of you have experimented with different sprockets, so I have a specific question.
    Please, I don't want a flood of answers, telling me a trillion combinations because that will just confuse me, so please just an answer to the following.
    On my RD04, I want to use a standard length chain, and the standard 16 tooth front sprocket. I'd like to knock a few teeth off the rear for better cruising speeds and fuel economy, but don't want to affect acceleration too much.
    What rear sprocket should I go for?
    I've searched through the forum, but it all just gets too confusing, with some answers.
    Thanking you for your specific'ness
    Lord Robert
    Cabby's Avatar
    Cabby is offline SOTGATT
    London/Surrey
    Re: RD04 sprocket sizes
    Firstly...E = m c(2)....... Therefore and such that.......I dunno
    watch this space....
    composite is offline Junior Member
    Nov 2006
    Sweden
    Hello,
    Based on my own recent experience:
    16 in front and 43 in rear is what you can manage with a new chain at original length. I would suggest a slight reduction of the chain lenght in order to have a chance to adjust for future chain wear.
    My old restricted (50 hp) ex-German machine is able to follow the traffic with that set-up, even with luggage in wide cases.
    Hope you find this info usefull.
    BobA's Avatar
    Sussex Riviera
    Thanks Composite!
    Belgium
    Thanks Composite!
    Bob, did you try this combination ? how did you get on.... I'm doing lots of motorway miles and are keen to find a good combination.
    Matt
    BobA's Avatar
    Sussex Riviera
    Hello Matt
    Your question is well timed indeed.
    I've tried ordering a rear 43 tooth sprocket from UK specialists, B&C Express, only to be told they don't have it, or it's not available.
    Anyway, I have ordered a 44, so as soon as it arrives, I will fit it to see the difference.
    I'll be running a OE Honda 16 tooth front, Gold Xring DID chain, 44 tooth Renthal Hard Anodised alloy rear sprocket (I know before you all say it, but I wanted to try one!!) and I will be fitting a Scottoiler at the same time.
    Watch this space.
    Whealie's Avatar
    Lewisham, SE London
    Bob,
    I have a 17 front and 43 rear combo sitting here waiting to fit. So if you fancy an experimental ride before and after, you can help me fit them.
    Belgium
    Hi Bob, its a little crazy, the PO told me he fitted a -1 tooth rear for highway use, so I checked this evening and it is 43.. Africa Queens sell a standard rear at 525/16/45 OK 45 and then Wemoto sell a -2 tooth and in the notes says its a 44 !!! so any idea what is standard ?
    As mentioned I run a 16/43 at around 120/130 kph I'm at 5 k maybe 5.250 and its at this point the engine just changes note and it a little more rought... hense why I'm keen to stick with what I have or better it... speed isnt important just comfortable cruising... Please let me know how you get on...
    Cheers Matt
  1. Best sprocket sizes
    By Warthog in forum Dominator / FMX
    Last Post: 30-12-09, 09:38 AM
  2. XR250 - Sprocket Sizes
    By silky666 in forum XR
    Last Post: 01-01-08, 11:53 AM
  3. SLR650 sprocket sizes
    By Oscarthecat in forum Dominator / FMX
    Last Post: 12-06-07, 10:55 PM
  4. Sprocket sizes
    By Hennie in forum Africa Twin
    Last Post: 21-05-07, 11:54 PM
  5. Standard sprocket sizes
    By howiezowie in forum Transalp
    Last Post: 26-03-07, 08:52 PM
