Results 1 to 2 of 2
Thread: Right size of valve seats?
    Chris.R. is offline Member
    May 2008
    Cape Town
    Hi folks, does anyone have an idea of the correct size (width) of the valve seats? The manual says 1.5mm as a maximum, but a former BSA mechanic says it may be wider for better heat transfer to the head!? Apparently it would not compromise the sealing-effect as the pressure of the combustion will help with this anyway?
    I got mine re-cut (after 100'000km) at a good engine workshop and I saw they made them pretty wide and more than 1.5mm, I also can't see 3 angles cut!?
    Any clues? I looked through the forum but coudna find et...
    GSPD750's Avatar
    Calgary, Alberta Canada
    Re: Right size of valve seats?
    Sounds like it may be time for new ones if your machine shop cut them back more than the service limit of 1.5 mm.
  1. Seats
    By cabbage2404 in forum Africa Twin
    Last Post: 11-04-06, 05:42 PM
  2. Seats Again
    By Hugh Janus in forum Africa Twin
    Last Post: 18-05-05, 08:58 AM
  3. Seats
    Last Post: 10-04-05, 06:22 PM
  4. Seats
    By DM in forum Africa Twin
    Last Post: 13-10-04, 03:49 PM
  5. Seats
    Last Post: 13-07-04, 07:43 PM
