So I have the problem that the wiring connector under the tank is damaged, one wire is broken. Normally you can remove the connector spade, solder on the wire and refit, but thats not the case here it won't come apart .. I dont fancy pulling back all the wiring.. are there any tricks to fix this ?
Many thanks in advance for any pointers...
