Had an interesting chat with a technical guy from ELECTREXWORLD regarding the Regulator/Rectifier and although in his words there Reg/Rec is so much better than Honda's ,half the problem is trying to keep the unit cool.Most manufactureres tend to mount this unit out in the open allowing a good circulation of air .So do I move the unit elsewhere or improve the circulation ? If you move it you will have to extend the cables which incidetly would have to be soldered and the hole move to where and extending cables may add to the problem.I have opted for better circulation ,I have drilled six eight mil holes in the side panel and now you can look through and see the offending unit.When sat on the bike that part of the panel with the holes is still accesible to the windy stuff.I know only time will tell and all you guys with your shining pristine At's are thinking "drill holes" if it works its got to be worth it .By the way my bike is a nice shiny one and I dont think the holes look bad .![]()
