Results 1 to 5 of 5
Thread: Transalp motor in an @ ???????
    Lam's Avatar
    Lam
    Lam is offline Senior Member
    Jul 2007
    Kerry Ireland
    Has anybody here ever put a Transalp motor in a RDO4 frame
    If so any pitfalls,
    Thought I'd ask here before I got out my manual's and a ruler
    Bolton, Lancs.
    Re: Transalp motor in an @ ???????
    I recall that a forum member put an RD04 engine in a transalp frame successfully, so i would'nt expect much problem the other way round.
    PS
    are you using TA motor cos you can't find an @ motor? or is there some special purpose ?
    Lam's Avatar
    Lam
    Jul 2007
    Kerry Ireland
    Have an old frame and I've just come across a Transalp motor in good nick
    Now I've got a cunning plan
    Bolton, Lancs.
    Quote Originally Posted by Lam View Post
    Just utilising available resources then ? , just the sort of thing I'd do.
    ladder106 Guest
    The older Transalps (PD06 serial numbers) and maybe even the newer ones do not have an upper rear engine mount. This is not cast into the TA cases.
    This should not be a problem just leaving this bolt off as the Transalps do fine without it.
    The ignition systems may not match exactly. Transalps (at least the early ones we got in the States) have two crankshaft sensors. I believe the ATs and later TAs have only one. This is not an impossible problem it is just that all the ignition/coil wiring may not exactly "plug and play".
    The front engine mounts and exhaust systems are also a bit different. If you are trying to use an AT exhaust, the pipes are bent differently where they join the heads since the TA heads are a bit different.
    Also, check the chain-line after installation as the TA CS sprocket may not line up exactly with the AT rear sprocket since the older TAs used drum brakes.
    All my information is from guys in the States with PD06 Transalps that have installed AT or Honda nt650 Hawk engines. Your mileage may vary.
    Let us see photos, please
  1. Transalp 650 starter motor
    By vidnash in forum Transalp
    Last Post: 08-05-08, 10:32 AM
  2. Starter motor all the same??
    By Tjokk in forum Dominator / FMX
    Last Post: 18-11-07, 06:21 PM
  3. Jf Motor Sport
    By btbloke in forum Transalp
    Last Post: 26-07-07, 06:24 PM
  4. starter motor removal on a 650
    By daved in forum Transalp
    Last Post: 23-03-07, 06:28 PM
  5. MotorMover / Motor Boy
    Last Post: 10-12-04, 08:48 PM
