Hey guys
So I had the headlight assembly contact issue resolved and everything and working great until this morning when I went for a little ride. Turned the bike on and no headlights, no Hi beam indicator, no passing light this time either. Turn signals and rear running light/brake light works fine. So I go to the fuse box and find that the "Phares" 10-A fuse has gone. No biggie, I pop in a new one and turn the bike on.
Lights work fine, but then as I hit the passing switch, they flicker and die. Same thing as before.
Now, when I first got the bike, I noticed that the fuse box contained a 10 A, 10A, 15A, 15A. When I read the manual, and looked at the inside of the fuse box, it says it should be 3 10A fuses and a 15A. Is the reason I'm burning 10A fuses because I should have a 15A there instead? I'm also curious as to what the 10A, 15A refers to exactly. Is that the maximum current allowed through that fuse before it goes or is it the current which that circuit is running on?
Thanks guys
