Re: My AT, some questions
The idle screw can come loose (be broken off its mount. On one of my RD04s this has happened and it means I have to look for where it has fallen to as it is on about six to eight inches of rubber hosing.
As for the bars. If the bars are crooked in their rubber mounts, which would happen if the bike had a prang, then simply loosen (no need to remove) the two nuts underneath the top yoke and fiddle with the bars until you are happy then retighten them.
After a big off on Salisbury Plain once I rode with my bars almost at 45 degrees then as son as we undid those two nuts they sprang back to the correct position.
