Re: Rough running at low rpm + lazy tachometer.
The tacho fault is likely to have been caused by a failure in the regulator rectifier at some point which may have been replaced in the past. When the reg/rect goes and the bike overcharges, it can kill the tacho.
The rough low rpm running could be a number of things from tight clearances or muck in the carburettors to sticky choke plungers/cable. It's most likely not coils or CDI as these tend to either break down at higher rpm or just not work at all.
For the rough running I'd start with the carbs and strip and clean them. While they are out of the way, I'd do the valve clearances, change the plugs and also check the inlet rubbers.
The faults are probably not related.
