Results 1 to 7 of 7
Thread: R6 Reg Rec wiring
    Underground's Avatar
    Underground is offline Senior Member
    Sep 2008
    French pass New Zealand
    R6 Reg Rec wiring
    Help! I bought an R1 R6 regulator rectifier and it came without its wiring loom . It just has 5 spade connectors on the end of it with no identification so I dont know how to match them up to the colours on my RD03 , is there some way of identifying them ?
    AlanH's Avatar
    Bristol, UK
    Re: R6 Reg Rec wiring
    Place the r/r on a flat surface, fins upwards. Look at the connector with two pins at the top and three at the bottom. Pinout is as follows:
    +12v GND
    Yel Yel Yel
    Sep 2008
    Hey, thanks for that , you are a legend
    russt1969's Avatar
    russt1969 is offline Long Way Home 2010
    Aug 2008
    Cheam, Surrey.
    How did you get on with the regulator?
    Just changed mine for a R1 one. Bought off fleabay for £26.00. Lovely stuff. Multimeter test was fine. Just need the rain to bugger off to see if its sorted out the long distance problem of losing charge after about an hours riding with the lights on.
    Sep 2008
    Just got round to fitting it yesterday, with the original it read, idle 13.95, 2500 13.95, 5000 14.00, lights on it was ,idle 12.55, 2500 14.63, 5000 14.65.
    with the r1/r6 . idle 14.2 , 2500 13.88 , 5000 13.77 , lights on it is , idle 12.50 , 2500 13.50 , 5000 13.10 .
    Turned off the battery reads 12.68 and its probably a bit knackered as I've just done 30 000 k with it ,
    I seem to have been having the opposite problem to you rust , having to regularly top the battery up as the level would get below the top of the plates ,because I always ride with lights on it was constantly over charging.
    Thanks to the @ thread it was simple and neat to fit , I just made a loom of wires with spade connectors and plugged her in, there seems to be a spare black wire in the @ loom which isnt connected to anything now , does anyone know if that is a problem?
    AlanH's Avatar
    Bristol, UK
    Spare black wire shouldn't be a problem. Leave it unconnected. It's a switched 12v feed but the R1/R6 reg/rect doesn't need it (it was done away with on later AT's too as the reg/rect is different).
    As long as the charging voltages are good, job's done.
    kitped's Avatar
    kitped is offline Senior Member
    Jul 2007
    Cambs
    Interesting, I need a new rectifier/regulator for my RD03 is it only an R1 or R6 one that I have to look for (exept of course a genuine Honda item)? If it is onlt R1 & R6 what model year do I need? Thanks in advance
    Jason
    1998 RD07a White / Red / Blue
    1988 RD03 Marathon Replica Monster
    1989 RD03 Rally Fairing Work In Progress
    1984 QR50 The original mini motocrosser
    2001 KTM 50 Pro Senior
    1999 CR250 Mad crosser
    1996 ZX7R Green Meanie
    1976 CB500T Cafe Racer Work In Progress
    1989 RD350F2 YPVS Ying Ning Ning...
  1. wiring and electrickery
    By Whealie in forum Mechanical Advice
    Last Post: 03-09-08, 02:08 PM
  2. wiring up my sat-nav - sorry if this a done subject ?
    By Dominic_the_TA in forum Transalp
    Last Post: 21-06-08, 03:28 PM
  3. Wiring worries
    By sproggy in forum Transalp
    Last Post: 28-12-06, 03:25 PM
  4. Telephone Wiring
    By DaveS in forum Chatter
    Last Post: 27-09-06, 09:08 PM
  5. wiring off the ignition
    Last Post: 18-10-05, 04:15 PM
