Results 1 to 10 of 10
Thread: Indicator on with lights!
    Knobblywobbly's Avatar
    Aug 2008
    Bognor Regis
    Unhappy Indicator on with lights!
    My left hand indicator has started to come on when I switch on my headlights. Not flashing, just on. Both front and back indicators light up along with the green idiot light. While this is happening I can use the right hand indicator as normal, but the left hand one won´t flash. If I switch off the headlights the left hand indicator work normally.
    Any ideas what´s going on, and where I should start to look for the fault?
    (I hate electrics!!!!)
    Snaphappy's Avatar
    Mar 2008
    ExPat in Germany
    Re: Indicator on with lights!
    reckon your relays buggered
    no idea where it sits on your bike but if taking it off and giving a wipe down doesnt help try a new one out of your car Halfrauds will stock flasher relays and most garages
    good luck
    AlanH's Avatar
    Bristol, UK
    Bad earth?
    Mutley's Avatar
    May 2004
    Top of the hill
    Just a chance it could be fusing inside the control on the bars. Or have you already cleaned that out?
    I think the green light is only controlled by the gear linkage 'diode'? The clutch also has an electrical 'switch' on it at the bars. Perhaps they're all shorting? Hope this helps
    They/re easy to take apart & clean, just have a look and give it a dose of WD40
    It'll probably be more serious than that, in which case - Good Luck
    Lumiya's Avatar
    Ziost
    First thing I would say is a bad earth on the headlight/sidelight that's causing the voltage to earth through the indicators
    Steve T's Avatar
    Steve T is offline Hill Rider
    Oct 2004
    RidingAlongOnACarousel
    I'm with Kymmy - bad earth - enjoy the search
    anton88's Avatar
    my bets on the relay on the way out - they can do funny things when they start to fizzle out - but good luck with the search
    Lumiya's Avatar
    Ziost
    Quote Originally Posted by anton88 View Post
    As the indicator relay is on the positive side of the indicator switch and isn;t inline or connected to the indicators at all when the switch is in the middle it won't effect the indicators especially in relation to the headlights. So discount relay problems...
    Farmboy's Avatar
    Farmboy is offline Senior Member
    May 2008
    In My Own World
    I have to agrre with Bad Earth.
    Last time i had one on my very old MZ years ago, took me a week to find it. I started at the back of the bike and checked everthing working my way forward.
    Turned out to be the front headlight ( which was the last thing to check )
    Just be thorough and check everything and best of luck as they can be a right pain to locate.
    Aug 2008
    Bognor Regis
    Thanks for all the replies folks
    I´ll have to start searching for the dodgey connection. One thing that did happen though - the indicator came on when I turned the handlebars to the right. So at least it looks like it´s somewhere at the front, which narrows it down a bit.
  1. indicator problem
    By bazza in forum Africa Twin
    Last Post: 13-12-07, 10:18 AM
  2. led indicator question
    By Xander in forum Mechanical Advice
    Last Post: 15-05-07, 10:13 AM
  3. Anyone know about indicator relays
    By Austin in forum Mechanical Advice
    Last Post: 12-02-07, 07:49 PM
  4. indicator running lights
    By shnesdi in forum Transalp
    Last Post: 26-01-07, 12:20 PM
  5. Indicator Indicator
    By Rolo in forum Africa Twin
    Last Post: 01-01-05, 04:59 PM
