Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
Thread: Dreaded Choke Seizure
    Re: Dreaded Choke Seizure
    Quote Originally Posted by stageonesimmo View Post
    Yen, you reading my mind then?
    I could have written that! Well apart from the last bit about living in a field.....
    Well cut and paste it after knocking that bit off, I don't mind.
    Rolo's Avatar
    Rolo is offline Am I that old?????????
    Jul 2004
    weymouth
    Bloomin eyesight is going, peering in there wondering how the choke plungers come out, anybody tell me how. Do you need to remove the carbs??? It on the last of the 750"s 02 model. Think the front one is stuck open.
  4. #13
    angelo's Avatar
    Apr 2006
    West Wales
    Follow the cable down to the front carb after removing the side panel then unscrew the cable fitting- with loadsa luck you might be able to jiggle the plunger out - probably best after spraying copious amounts of wd40 and letting it soak
    If this doesn't work do as I did - remove the cablexand with a largish punch push the plunger all the way in putting something behind it to fill the void then put the cable screw back
    Ok no choke on front carb now but it is fine and works really well
    Hope this helps
  5. #14
    Rolo's Avatar
    Jul 2004
    weymouth
    Will give it a go thanks guys.
  1. Dreaded Salt on the Roads Already
    By The Mountie in forum Travel
    Last Post: 07-10-08, 08:08 AM
  2. SLR choke
    Last Post: 01-10-08, 01:26 PM
  3. Choke....again
    Last Post: 13-07-08, 06:37 PM
  4. b*st*rd b*st*rd b*st*rd choke - AGAIN
    Last Post: 27-04-07, 09:19 AM
  5. xrv 750 choke
    By jabba in forum Africa Twin
    Last Post: 12-12-06, 08:05 PM
