Results 1 to 4 of 4
Thread: Lights/horn.indicator switch assembly
    R0vers's Avatar
    R0vers is online now BLUE 1999 xrv750x
    Mar 2007
    South London/Somerset
    Hi guys..
    my main beam switch button has died on me - and i have tried stripping it dowm - but it dosent seem to want to play...
    does anyone know if the varadero or transalp switch assembly is the same? and could i just use this.. seems finding a RD07A one is like hens teeth...surprise surprise..???
    Any thoughts?
    TLD2008 15.41
    Re: Lights/horn.indicator switch assembly
    I know the Varadero 2000 model is the same as the 2000 AT cos I lent my spare switch to my mate until he could get a replacement himself and it went straight on. Never got it back, he sold the bike!!
    R0vers's Avatar
    Mar 2007
    thanks yen - the look identical - hence the question - they are much easier and cheaper to come by than the identical @ part...
    thanks again!!!
    TLD2008 15.41
    jasonbc's Avatar
    Camborne, Cornwall
    Quote Originally Posted by R0vers View Post
    Hi guys..
    Any thoughts?
    I'm 99% certain there all the same. I broke the switchgear on my xr400 and couldn't get one for sensible money i did get a brand new one from a breakers from a 2003 nsr125. It was the same switch gear just had to change some wires around in the plug.
    They do come apart easily and if you want you could just de-solder the faulty switch and solder the new one in
    GASGAS TXT250 PRO 2006
  1. Indicator on with lights!
    By Knobblywobbly in forum Africa Twin
    Last Post: 26-10-08, 08:31 PM
  2. Transalp horn - leads to horn?
    By alpslapper in forum Mechanical Advice
    Last Post: 24-09-07, 11:44 PM
  3. indicator running lights
    By shnesdi in forum Transalp
    Last Post: 26-01-07, 12:20 PM
  4. Clutch lever assembly wanted
    By squirrelciv in forum Dominator / FMX
    Last Post: 02-03-06, 06:34 PM
  5. Indicator switch gear from AT
    By space in forum Transalp
    Last Post: 06-04-05, 04:01 PM
