Results 1 to 9 of 9
Thread: xtz 750 super tenere
    kennymact's Avatar
    Sep 2006
    christchurch/newzealand
    Looking at a 1990 tenere and how does it compare to the africa twin,any comments ,experience,tips welcome...
    Re: xtz 750 super tenere
    from what I have seen of them they are an imitation, they do not have the Honda ruggedness.
    Other than that they seem well capable.
    Larry Biskit's Avatar
    Larry Biskit is offline Now down under
    Jul 2006
    New Plymouth , New Zealand
    A mate has one, having ridden it and with him for many miles, can say I like it, just faster than my @, (up to 100kph). With the smooth parallel twin, it felt slim and nimble, but many things similar to the @. Maybe didnt handle as well in turns, couldve been his old tyre though. Mate says its great offroad, good bike all round, be nice to own one.
    Gaz's Avatar
    Gaz
    Gaz is offline ... and this is me
    North Wales
    Hi Kennymact, I've had both. Had the Super Tenere about 10 years ago and have the AT now. If I had a choice of either now, I'd go for the Africa Twin. Better handling, better looking, easier to get spares for, spares are generally cheaper too. I think the Africa Twin seems to be held in higher regard by other bikers too (apart from Tenere owners of course). Having said that, the Tenere was extremely reliable (just like the AT), and could pretty much go anywhere (just like the AT). I think the AT is a bit heavier, so if you dropped the Tenere (like I did), it wouldn't be too much hassle lifting it by yourself, whereas I struggled when I dropped the AT.
    As balanced a persepctive as possible, hope it helps.
    Gaz
    Zenarchy's Avatar
    North East UK
    I've got an old copy of a motorbike magazine from 1990 where they review the tenere, africa twin, and cagiva elephant side by side.
    The cagiva comes out tops, followed closely by the africa twin, then the tenere (which didn't seem to fair so well - though this may have been due to comparisons with a previous model if my memory is correct - been a good while since I read it).
    You won't be able to PM me because you haven't subscribed to the forum yet, but if you can post your email address here (obfuscate it by putting spaces in and replace the @ sign with another symbol so the spam bots can't pick it up), and I'll see if I can scan it and email over the article for you.
    Or I could post it here if that's OK with the admins (not sure if I'll get wrong for that it being from a magazine - but it is an old one so may be OK).
    chronyx's Avatar
    Surrey, UK
    Would be cool to see it...
    Underground's Avatar
    Underground is offline Senior Member
    Sep 2008
    French pass New Zealand
    Are you looking at that one on TM ? Looks real tidy. I know of a couple of guys down your way with S 10's and will be riding with them in the DB1K09 so it will be interesting to see if they can cut the mustard against the mighty RD03 .If you are a member of the Kiwi Biker forum check out the adventure dual purpose threads and you will find them there.
    Mostly the difference seems to be rivalry between the owners of both models , but if anyone knows I would be interested to know how much each cost new back in the day ?? The most expensive one could then be considered the best (or mabe not ?)
    Lumiya's Avatar
    Lumiya is online now The Dark One
    Ziost
    S10's are faster and tend to be cheaper, also a lot of people swap out the 750 motor for a TDM850 (the later ones have a 270 degree crank that gives them a lot more torque) and there are even a few mods currently on the go with different people putting in the tdm 900cc internals/barrels complete with the EFI. If you go for one then look out for cracks in the rear engine mounts, corrosion on the rear sub-frame and front sprockets welded into place...
    Zenarchy's Avatar
    North East UK
    Quote Originally Posted by Underground View Post
    I've just found the magazine article I mentioned (Superbike October 1990) shows the prices of the three bikes as:
    Cagiva Elefant : £7750
    Africa Twin: £5350
    Yamaha SuperTenere : £4259
    They came out in the same order in the review too, with the Elefant top and Tenere being least favourite (so you may be right about the more expensive being best - though it was up against some tough competition and this is only the reviewers opinion ofcourse - I know some people have been around the world on them so they can't be that bad - they look great to my eyes - particularly the older ones - though I have a soft spot for 80/90s trail bikes).
    I'll try to get it scanned in a bit later (don't have a lot of time right now as I'm waiting for a phone call and can't leave the phone).
  1. super Tenere fuel tank wanted
    By ilizarovman in forum For Sale / Wanted
    Last Post: 30-06-08, 07:48 PM
  2. Xtz750 Super tenere
    By Palmer in forum Yamaha
    Last Post: 17-03-08, 01:03 PM
  3. New Super Tenere - Honda where are you??
    By Lord Stig in forum Other Bikes
    Last Post: 22-02-08, 07:39 PM
  4. micro fiche for super tenere
    By Papa Pete in forum Other Bikes
    Last Post: 19-06-07, 07:54 AM
  5. super tenere
    By cbcommuter in forum Other Bikes
    Last Post: 29-10-06, 05:41 PM
