Results 1 to 4 of 4
Thread: Engine painting. Advice needed.
    sixtring74 is offline Senior Member
    Dec 2005
    Peterborough
    Hi Guys.
    Advice if possible. I have a bike engine stripped back to the ally cleaned and degreased. Now I need to paint but don't know what paint to buy for the job.
    With you're wealth of knowledge you must know.
    Cheers Brainiacs
    XRV750 Africa Twin, Geared to tour. KTM 250 EXC ready to Race. Riden, filmed and Edit two Adventure Motorcycling documentaries -Aim For The Horizon and Adventure Motorcycle Morocco - Would love to tour the World... Watch this space.
    GSPD750's Avatar
    Calgary, Alberta Canada
    Re: Engine painting. Advice needed.
    If your a beginner then you may want to look at the following kit.
    http://www.holden.co.uk/displayprodu...?pCode=094.933
    Traveller's Avatar
    Traveller is offline Senior Member
    Nov 2008
    Derby
    First thing to condider is only go for thin coverage, thick coatings crack and flake. I would never brush paint as it will allways go on too thick.
    Use a laquer/celulose or if the colour is available use a colour from Hammerite smooth range. Preparation is very important. Alloys almost instantly oxidise and this causes problems with adhesion. Wire wool the surface or use one of those green scouring pads, wipe with a de greaser and then imediatly spray a relativly fine coat of etch primer, (available in aerosol cans, use a carbon mask) then a fine base coat (primer surfacer) followed by the colour coat.
    If the paint is on too thick it will bubble and discolour round the hotter parts (round the exhaust).
    I try and use the Hamerite products if a colour in the range a colour suits otherwise I use celulose based products a this withstands heat and is a thinner finish.
    I have painted engines, calipers and other parts that are subject to harsh environments in this way and find it to be the best solution. Good luck
    RWB XRV 750
    Red XRV 750
    GL 1800
    Yellow Honda CT90 Trail
    Red Honda CT90 Trail
    Horses for courses
  5. The Following User Says Thank You to Traveller For This Useful Post:
    foz1969 (26-01-12)
  6. #4
    Mervinh's Avatar
    Nov 2006
    The dark side of Dartmoor
    Silver paint?? PJ1 used to do a good one but stopped making it for some reason but this is good i am told
    http://cgi.ebay.co.uk/YAMAHA-TY80-TY...713.m153.l1262
  1. Advice needed!!
    By ABZ in forum Africa Twin
    Last Post: 02-12-08, 09:08 PM
  2. Painting & engine question
    By Santiago in forum Africa Twin
    Last Post: 01-05-08, 12:00 PM
  3. Help/advice needed please
    By anton88 in forum Chatter
    Last Post: 22-09-06, 01:57 PM
  4. Painting engine cases
    Last Post: 29-08-06, 11:16 PM
  5. Advice needed.
    By stumpylegs in forum Transalp
    Last Post: 21-01-06, 08:12 AM
