Results 1 to 10 of 19
Thread: 100w headlight bulbs
    BIGROG's Avatar
    BIGROG is offline I need a hug!
    Apr 2008
    On the move yet again... bak dan south!!!
    Question 100w headlight bulbs
    I have been through all the old posts and seems a few members have/are using 100/80 headlamp bulbs in their ATs, not being a sparky will the wiring/relays handle the extra wattage, I can't afford the HID ones right now and I have some 100w bulbs here and the fairing off at the moment so should I fit them.
    Thanks Rog
    IM ON THE SAFEHOUSE LIST
    Big white LWB Renault Master Van, mobile home for me,Tess and the bikes
    Kjell Lindberg's Avatar
    Sweden
    Re: 100w headlight bulbs
    The wiring should be 1,5 sqr mm to cope with the current for 100W.
    Usually the wires cope with the extra load.
    If you have relays in the circuit, check their rating so that they do not burn their contacts solid due to the extra load.
    There is an substantional difference in light between standard and these "For Rallye use only" bulbs
    But they will produce more heat, and many reflectors do get "cloudy" with time. I'm not sure about the AT reflectors and if they can take the stress over a longer period without ruining the silver coating on the reflector.
    BIGROG's Avatar
    Apr 2008
    Thanks for the input it's just that I have these 100w bulbs sitting here and the AT in bits but I don't want the loom to end up looking like Amy Winehouse's hair
    Sohoeasy's Avatar
    Sohoeasy is offline Stone Chiller.
    May 2005
    Westminster London
    Quote Originally Posted by BIGROG View Post
    Here we Go!!!!!!!!!!!!!!!!!
    Bolton, Lancs.
    Some time ago i bought a CB900f that had the best headlight beam i had ever had. even in daylight when i pulled up behind cars they would flip their mirrors up !! ( i always use high beam in daylight).
    Only problem with the bike was a seemingly iffy battery as i frequently had to bumpstart it.
    When the headlight bulb eventually blew i found it was a 80 /100 watt bulb. I replaced it with a normal 55 / 60 watt bulb, the resulting light beam was pathetic by comparison , but the upside was that i no longer had to bumpstart the bike.
    Obviously the generator output was not enough to run the 100 watt bulb and charge the battery.
    So this is something to take into consideration.
    Robster's Avatar
    Feb 2005
    Shepperton
    Whack some proper HIDs in it Rog....£100 for the complete kit.
    SUCH a difference
    Apr 2007
    East Anglia-ish
    The twins don't like HID Rog you have to have perfect joins and it will fail MOT as its not a HID lamp.
    Also your tripmeter will keep blanking out.
    AND A BIG UP TO IBN BATTUTA
    ADVERTISE HERE.
    Absynth eye drops
    see things in a new way
    BIGROG's Avatar
    Apr 2008
    There are many opinions on this headlight bulb thing I know, but I can't run to HIDs at the moment and I have the 100w bulbs here to be used so If I fit them will it bugger the wiring or relays, I am quite happy with the standard bulbs but had 100s on my Intruder and they give a better light by far, I am naff at doing wattage/amp wire size equasions, But I can't half lift things
    Rog
    BIGROG's Avatar
    Apr 2008
    Quote Originally Posted by meljordan View Post
    Mel I thought you were well pleased with your HIDs, they looked well bright when you turned up at the Ace last week Mate.
    Apr 2007
    East Anglia-ish
    Normal lamps buddy i just cleaned the inside of the housing. The Hids kept blanking my tripmeter thouge they worked well every time i manually redone the joints as soon as i went out one would keep offing so i slayed the fekkers......Felt good,,,,,,
    ADVERTISE HERE.
    Absynth eye drops
  1. XL700 headlight bulbs
    By Nareef in forum Transalp
    Last Post: 17-05-09, 04:16 PM
  2. Xenon Headlight Bulbs
    By btbloke in forum Transalp
    Last Post: 10-06-07, 09:50 PM
  3. Replacement Headlight Bulbs?
    Last Post: 12-03-07, 04:30 AM
  4. Headlight bulbs at Halfords
    By lootch67 in forum Chatter
    Last Post: 01-11-06, 11:28 PM
  5. Headlight bulbs
    Last Post: 16-11-05, 01:01 PM
