Hi all, after putting the new airbox rubber on the RD03 and making sure there were no air leaks i went out on it last weekend i noticed a small misfire once but thought nothing else of it........................
however i went out on it today and on 3/4 to full throttle it holds back and misfires. i was about to fit a new fuel filter and whilst the tank was off i decided to put the old plugs back in in case it was a plug problem................ it wasn't!!!
any ideas ????
do you think that the mixture is wrong now there is no air leaks ???
i checked the plugs on a plug chop and all 4 were nice and clean, by making the air box air tight it would make the mixture slightly richer if anything but the plugs didnt show this.
could it be a coil, i hope not as this could prove difficult to diagnose,
my next thing to look at will be to remove the carbs and remove the float bowls to see if theres any crap in there, i'm hoping that something has partially blocked one of the main jets. i've never had the carbs off before and wasnt going to touch them until i strip the bike down in the winter but now i have no choice.
is there anything i should know regarding removing the carbs/disconnecting cables etc etc.
thanks
