Hi all, i've put a post on regarding a misfire. I was reading through previous posts regarding misfires and a few mention choke cable. Am i correct in thinking that the choke lever should fully return when released as mine goes back about a 1/3 but you have to push the lever away from you to fully close it.
If i disconnect the chokes to see if that is the problem do i need to blank the holes up before i run it ??
thanks
