Results 1 to 10 of 17
Thread: Strange sound
    Dec 2008
    Nairobi, Kenya
    Unhappy Strange sound
    When riding it sounds like something metal (i think) is loose. it rattles and sounds like a loose screw. Sounds like right under the tank somewhere. did strip it off and could not find anything loose, so wondering if it could be inside the engine and if it has happened to any before and what they found the sound to be.
    1gear1brake's Avatar
    Portland, Dorset
    Re: Strange sound
    It could possibly be your bashplate. Try putting your foot on it when you hear the rattle and see if it goes away. Mine was doing this. It turned out to be the bashplate vibrating againt the s-shaped exhaust heat shield.
    Good luck
    Dylan
    Lumiya's Avatar
    Ziost
    Re: Strange sound
    A loose bash plate or simply a screw/bolt/stone sat inside of it can casue the most horrendous of noises
    BobA's Avatar
    BobA is offline xRv PiMp ;-)
    Sussex Riviera
    Re: Strange sound
    Hello again!
    Is it an RD03 or RD04 you are riding?
    If so, check the front side panels, where they wrap over and touch the tank, sometimes vibration at certain revs causes the panel to rattle or buzz against the tank.
    If you remove the side panel, you will notice that there is a metal strengthing part on the underneath of the curve of the panel. gently tweak this and it should cure the problem.
    kitped's Avatar
    kitped is offline Senior Member
    Jul 2007
    Cambs
    Re: Strange sound
    Had this on my RD07a, it was the bash plate, only done it when excellerating hard or reving up to about 5 when standing.
    1998 RD07a White / Red / Blue
    1988 RD03 Marathon Replica Monster
    1989 RD03 Rally Fairing Work In Progress
    1984 QR50 The original mini motocrosser
    2001 KTM 50 Pro Senior
    1999 CR250 Mad crosser
    1996 ZX7R Green Meanie
    1976 CB500T Cafe Racer Work In Progress
    1989 RD350F2 YPVS Ying Ning Ning...
    chronyx's Avatar
    Surrey, UK
    Re: Strange sound
    I'd be more worried if mine didn't rattle bless it
    kennymact's Avatar
    Sep 2006
    christchurch/newzealand
    Re: Strange sound
    I had a strangle rattle and it turned out a spare key on my keyring was rattling on the top yoke....
    Oro's Avatar
    Oro
    Oro is offline Senior Member
    Feb 2005
    Hereford, England,UK
    Re: Strange sound
    or your exhaust guard ?
    Re: Strange sound
    Or your teeth.
    Dec 2008
    Nairobi, Kenya
    Re: Strange sound
    funny and helpful. thanks. i did remove all panels and the guard and still the sound is there. as long as it is not something loose inside the engine then i am not too worried but must say a bit irritating. It is definitely something loose. Living in Kenya the roads are well not good and when riding on it that is when the rattle is most audible. Definitely something falling around rather than a vibration. will remove the bash plate this weekend and hear if still there.
    thanks again
  1. Strange sound from the rear end.
    By LUNLUNZAI in forum Varadero
    Last Post: 19-07-08, 10:23 PM
  2. A strange, strange thing .......
    By owdoggy in forum Chatter
    Last Post: 15-04-08, 06:37 PM
  3. Strange clunking sound...
    By Nareef in forum Transalp
    Last Post: 23-03-07, 06:16 PM
  4. Strange clicking sound
    By rlkat in forum Transalp
    Last Post: 31-01-07, 01:16 PM
