Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 43 of 43
Thread: Carb overhaul mileage
  1. #41
    Hodgo's Avatar
    Hodgo is offline Honda Adventure Rider
    Jul 2009
    Australia (Brisbane)
    Re: Carb overhaul mileage
    To be sure to be sure. I replaced the fuel pump. Needed to be done anyway.
    I also replaced the R/R with a sh548-12. It still gets just as hot as the old one. So the old one could have been alright for a while yet. But at least i know now its new.
    Bike still wont accellerate under load. Just now power. Idles fine.
    Any suggestions before i pull the tank off and start at the carbies ?
    Lack of power under load usually means blocked air filter.
    Wrong air fuel mix, using the idle jet it works fine using main jet it does not.
  4. #43
    Hodgo's Avatar
    Jul 2009
    Suppose this is a lucky find, Could have been worse. Rear Plugs were black. So started with the rear carbie. Undid the bowl and the Main Jet Fell into my hand.
    So after putting that back together etc all is well again.
    Either I failed to do it up tight enough last time or it just came loose under vibration.
    End result is fixed. I can rest easy now.
  1. the overhaul or not
    By AlexRu in forum Africa Twin
    Last Post: 17-07-08, 12:42 PM
  2. Engine overhaul or not...
    By sterzam in forum Africa Twin
    Last Post: 20-08-07, 05:46 PM
  3. Winter overhaul
    By markh in forum Africa Twin
    Last Post: 29-12-06, 06:33 PM
  4. overhaul
    Last Post: 16-03-06, 05:11 PM
  5. Brake overhaul
    By gibbo in forum Africa Twin
    Last Post: 29-03-04, 08:37 AM
