Re: Valve set, starter needed
Originally Posted by
pushaqwari
Thanks very much for your e-mail, but this diagram does not say me how the valve starter, works. How does the valve start connect to the choke's cable?, What is the procedure to assemble the choke's system?
thanks again, regards
luis
I think that you push the cable through the plastic body then put the spring onto the cable, compress it, feed the cable through the metal plunger sideways, turn it so it is straight on the cable and when you let the spring go back into tension it holds the plunger on.
Or you can get rid of the choke and never worry about it again.
