Results 1 to 9 of 9
Thread: Possible Regulator / Rectifier Failure
    slanty's Avatar
    slanty is offline Senior Member
    Apr 2008
    London
    Hey All,
    My @ seems to be suffering a bit lately, first there was the speedo that stopped working and now I think the regulator may be fried...
    I was out on the bike yesterday but when I stopped and parked up the bike my dyna charge monitor leds stayed on even when I removed the keys (it usually goes off when I turn off the bike). It was the green light that was staying on so I wasn't too concerned.
    But when I got home, and parked up again, the led light stayed on again but this time it went to red, indicating that there was a draw on the battery, even though everything was off and the keys were out.
    To prevent any damage I disconnected the battery.
    I have been told by a couple of people that this may be the regulator / rectifier. Do anyone else here think this may be the case?
    What should I do to try and diagnose the problem? I don't want to buy a new regulator unless I have to (I'm still a bit skint after Christmas).
    Cheers,
    Stef
    AlanH's Avatar
    Bristol, UK
    Re: Possible Regulator / Rectifier Failure
    Get hold of a multimeter and check out the charging system properly.
    Follow this:
    http://www.electrosport.com/technica...ng-diagram.pdf
    Take off the dyna charge monitor first to make sure that doesn't interfere with any readings.
    GSPD750's Avatar
    Calgary, Alberta Canada
    Quote Originally Posted by slanty View Post
    Hey All,
    Cheers,
    Stef
    Your Dyna Charge Monitor should be wired to the "switched" side of the ignition, so that it only illuminates with the key on. I would bet your charging system is just fine and that you need to sort out the wiring for the Dyna as it is now obviously "hot" to the battery.
    slanty's Avatar
    Apr 2008
    London
    Follow this:
    Thanks for that Alan, I'll give that a go today. Cheers for posting the link, I did see a similar link in an older post but the link was broken so thanks again.
    Quote Originally Posted by GSPD750 View Post
    The Dyna Charge Monitor has been on the bike since I got it so I'm not sure how it is wired. I'll check it today also.
    By the way GSPD750, are you the fella I met at the Touratech event with the AT with the Rothmans fairings on it?
    Cheers,
    Stef
    GSPD750's Avatar
    T
    Cheers,
    Stef
    Not me. You do know that I'm in Canada...right?
    slanty's Avatar
    Apr 2008
    London
    Oh yeah, just spotted that now..duh
    I met someone at the Touratech event who had username ending 750 but I can't remember what the name was... ah well...
    Thanks for the advice, I'll let you know how I get on with the bike.
    slanty's Avatar
    Apr 2008
    London
    Hi AlanH, GPSD750,
    Sorry for not posting sooner but it has been wet / raining the last few days so I didn't want to be playing with the electrics.
    Anyway, I don't think there is a problem with the rectifier or the battery because I followed the fault finding diagram and it indicated that everything is ok (except for maybe cleaning the connections).
    I removed all the extra connections (dyna charge monitor, power sockets, starcom socket etc) from the battery and then I used the multimeter to check the battery and it is giving 12.6V when the bike is off.
    When I started the bike and revved it to 2500 rpm, the reading was 14.3V and when I revved higer to 5000 rpm, it stayed at 14.3V +/- 0.05V. According to the diagram this means the regulator / rectifier is ok so I assume that something is wrong with the Dyna Charge Monitor (especially since it was staying on even when the the bike was switched off) or maybe one of the power sockets etc that I removed.
    I think the Dyna Charge Monitor was correctly wired to the "switched" side of the ignition because it used to only come on when I turned the key. It is probably a loose connection or a short somewhere I think, do you agree?
    I guess the bike is ok to ride again now (I wasn't using it because I was worried a failing regulator or rectifier would do damage) so I am going to take to my garage and strip it down so that I can examine all the wiring and give the connections a squirt of WD40.
    Thanks for the help and suggestions,
    Stef
    AlanH's Avatar
    Bristol, UK
    Those readings sound fine. Duff monitor or iffy socket wiring it is. Probably the cheapest option
    slanty's Avatar
    Apr 2008
    London
    Super Stuff!
    That's what I was hoping to hear, Cheers Alan
  1. regulator/rectifier
    By LEOPARD in forum Africa Twin
    Last Post: 04-08-08, 07:00 PM
  2. Regulator/Rectifier
    By fatowl in forum Transalp
    Last Post: 26-07-08, 09:53 AM
  3. regulator/rectifier
    By Magnum PI in forum Africa Twin
    Last Post: 02-05-08, 09:46 PM
  4. how hot is your regulator/rectifier?
    By fergus1964 in forum Africa Twin
    Last Post: 01-10-07, 01:46 PM
  5. rectifier/regulator?
    By ROYMACNIC in forum Africa Twin
    Last Post: 09-04-06, 08:50 PM
