Results 1 to 7 of 7
Thread: Ignition dilema
    Bongoman's Avatar
    Bongoman is offline Member
    Jan 2009
    Cambridgeshire
    Ignition dilema
    When I bought my RDO4 the previous owner informed me that there was a theft attempt on the bike and the thieves broke the steering lock. I bought a replacement ignition switch from AlanH and very greatful for his service. I just have a small dilema in that, when I took mine apart to compare I realised that the one I bought is slightly different. The actual body of the switch fits fine, the barrel is slightly longer but thats not the problem. I have realised that there are more wires attached to the replacement switch. The old one has three wires, red, blue red & red black. The other one has red, black,2x brown, brown white. I compared the electrical diagrams in my haynes manual but none of the diagrams represent the new switch. Does anybody know how i can adapt the wires to suite my bike. If i can find out the function of the several wires on the new switch, maybe i could check my diagram and the ones that coinside with each other i can connect. Please help me somebody.
    BobA's Avatar
    BobA is offline xRv PiMp ;-)
    Sussex Riviera
    Re: Ignition dilema
    Bongo'
    That's a bit puzzling!
    Both RD04's but different wiring? Is the connector the same orientation with the same amount of ways in it? Are any wires doubled up or do you have extra pins?
    I'm nowhere near my Haynes manual at the moment, so can't advise exactly. Worse case scenario, you could probably make it work, but you need to go through everything with a multimeter and connect similarly.
    Also, if you look at the bottom of the switch, there is usually a round plastic cover which you can carefully pry out. You will then see the wires soldered onto the switch contacts,, so you can count if they are same/similar or have more poles.
    Good Luck
    futter's Avatar
    Jul 2005
    Suffolk
    Re: Ignition dilema
    Trial and error mate.
    I have done this before and it takes a short while but you should be ok provided you are not a complete numpty.
    Bongoman's Avatar
    Jan 2009
    Cambridgeshire
    Re: Ignition dilema
    Try me bro, completely numpty. no not really, ok ill open it up further and check. what other functions could the newer bike have in terms of the switch function?
    Re: Ignition dilema
    Ignition switch should have 4 wires colours vary.
    2 wires are for the side tail lights,
    2 wires are for the ignition.
    When the ignition is turned on the battery feed goes to the starter solenoid, and a feed goes across to power the side lights.
    Check the manual against your feeds, check at the plug, and match the feeds.
    Bongoman's Avatar
    Jan 2009
    Cambridgeshire
    Re: Ignition dilema
    My old switch has only three wires which go to a plug so i want to adapt the new one which has 5 wires and the manual only shows the three wires which. I dont know what the 5 wires from the new switch are for. I might have to trial and error it. Does anyone have the wiring diagram from the newer bike with more than three wires, i dont know the year of the bike it came from, i might have to ask AlanH
    Bongoman's Avatar
    Jan 2009
    Cambridgeshire
    Re: Ignition dilema
    Cheers guys, AlanH has answered my question.
  1. Suspension dilema
    By jasonbc in forum XR
    Last Post: 07-09-08, 06:25 PM
  2. Dilema
    By Palmer in forum Chatter
    Last Post: 16-07-08, 05:56 PM
  3. DataTool System 3, charging battery dilema
    By mgillespie in forum Mechanical Advice
    Last Post: 25-02-07, 06:59 PM
  4. Ignition
    By jpc in forum Africa Twin
    Last Post: 18-11-06, 09:59 PM
  5. Windscreen Dilema
    By usatic in forum Africa Twin
    Last Post: 02-12-05, 09:09 PM
